ralliart spoiler brake light
Will the 2004-06 ralliart spoiler's brake light work on the es 04-06 model? or does the oz and ralliart models have special wiring for it?
one way to check is pop ur trunk and look to see if theirs wiring in the trunk intelf.. it follows the trunk latch cable.. if the cable is present then yes to that answer,
if not u can still run that ra spoiler with the light u will just have to splice into the 3rd brake light harness.. that is located inside the trunk under the rear deck.. my oz had the drop for it but no light since my spoiler had the light built it but since i went to the evo wing, i found a used 3rd brake off a evo and installed it
ok i took your advice and looked under the trunk and found this. here is a picture. its just a random connector not connected to anything but the spoiler has just a wire with the end frayed so i dont know if thats the connector or not.
yeah haha i meant trunk. it was hanging pretty close to the middle of the trunk a little off to the right. so if thats the connector and the spoiler only has a wire, how would i connect the two? electrical tape or something?
evo8usa
Mar 29, 2005 06:34 AM
dmeluzio22
May 14, 2004 01:37 PM
jbizzle
May 14, 2004 08:58 AM
