Rear engine and transmission mounts the same?
Old Dec 30, 2010 | 03:01 PM
kevin10's Avatar
A friend is putting new transmission mounts on my car. Says need a new front and rear. Said if i bought parts,he'd do the labor. I went to O'reillys. They said only just saw one transmission mount listed. They had a rear engine mount listed. Guy said he would just order everything that came with it *Sigh*
So is rear engine mount same as a rear transmission mount? I need to know..im confused and dumb also..
Have an 03 oz ..automatic
Old Jun 10, 2015 | 12:40 PM
dayvidswrong's Avatar
I'm sure you already got your answer since its been 4.5 years ago from the day of your post. In case another person was wondering: there are 3 engine mounts and 1 transmission mount. I have an 02 oz; our cars shouldn't be much different.
The transmission mount is located on the driver's side under the battery.
Front roll stop mount is front center. It is bolted onto the crossmember(long mental support bar).
Rear roll stop is rear center.
Front/Side mount is on the passenger's side below the power steering fluid.
rpm_ruffryders
Lancer Engine Tech
603
Mar 3, 2020 07:04 AM
zerocool_b
Sep 28, 2015 02:23 PM
david23
Lancer Engine Tech
Jan 23, 2014 11:03 AM
therunningskier
Sep 29, 2010 12:45 PM
EvilEvo789
Dec 10, 2007 02:27 AM
