CE Gear ratio
Old Feb 1, 2011 | 02:05 PM
avn_0071's Avatar
Question CE Gear ratio
Hi, does anyone have any info on the transmission and differential gear ratio for a lancer '99 ce 1.5 5sp manual? I just want them to get the speeds calculated at different gears...
Old Feb 1, 2011 | 02:37 PM
senate6268's Avatar
Here's what I have for the USDM Mirage:
F5M41 - 1997+ 1.5L Mirage
1st - 3.583
2nd - 1.947
3rd - 1.343
4th - 0.976
5th - 0.804
Fin - 4.052
I don't know if it would be different for the Australian market Mirage.
Old Feb 1, 2011 | 03:49 PM
avn_0071's Avatar
Thumbs up Cheers
Thanks for d info. These are the calculated speeds(mph) corresponding to engine rpm. I have used the tyre size of 195/55R15. My car would do 100kph(5th gear) speed about 200rpm less than this data. Let me kno if this seems alright for your car. I just wanted to check wether or not the clutch is slipping, or by how much amount....
Original Equipment Tire Tire Width in (mm): Aspect Ratio: Rim Diameter in (inch): Transmission Gear Ratio: Differential Ratio (final drive):
8000 7500 7000 6500 6000 5500 5000 4500 4000 3500 3000 2500 2000 1500 1000
Old Feb 1, 2011 | 03:54 PM
avn_0071's Avatar
The format did not allow me to present the data. Here it is:
Tire Width in (mm):195
Aspect Ratio:55
Rim Diameter in (inch):15
Transmission Gear Ratio:0.804
Differential Ratio (final drive):4.052
RPM to Speed(mph):
1000-21.41
1500-32.11
2000-42.82
2500-53.52
3000-64.23
3500-74.93
Llew
21
Nov 19, 2025 06:38 PM
Andrie
Nov 2, 2007 05:19 PM
AZ EVO IX MR
Mar 13, 2007 07:12 AM
MrAWD
Mar 30, 2006 02:37 PM
agsmooth84
Lancer Tranny/Drivetrain Tech
Jul 7, 2002 12:26 AM
