Lancer won't start, help?!
Old Jun 26, 2011 | 10:02 PM
06LancerRA's Avatar
So I drive a 2006 Lancer Raliart, 2.4L, and it won't start, here's what I've tried, and the problem:
My fuel light came on, I drove for about twenty kilometers, filled up with shell v-power premuim, as per usual, (91 Octane), then drove about 30km on the highway, all was well, I cruised throughout the city, doing my errands, etc, getting out of the car between 5 and fifteen times, starting sounded normal, then I was stuck in traffic in edmonton, alberta, for two hours, moving about fifteen feet at a time before I finally got onto the highway again. Drove about twenty kms, stopped for some food, got back into my car, and it wouldn't start. (58 kms on the full tank)
Sounded to me like the battery was dead, as it was turning over, but not starting, like it just didn't have enough juice. I checked for vapor lock by opening gas cap, tried boosting it, then let it sit overnight, and hauled it home today. I listened to the fuel pump with the key on, and it sounds like it/s pumping. Tried boosting it once more, no go. Tried pull starting it (5-speed), checked fuses for fuel pump and ignition.
I've only had it for about 5000 kms, and it's currently at 158,000, but I swapped plugs when I got it, (with what I was told were OEM replacement), fresh oil change, and have only run premium for the while i've owned it. As long as i've had it, it doesn't have trouble starting, but sorta takes a second or two to turn over, like it has weak battery, sorta whiir-whiir-start sounds, even when hooked up to charger/booster cables. Now it's doing the whole whiir-whiir-whiir-no start thing. Anyone, help?
Old Jun 26, 2011 | 10:19 PM
02-Lancer-Es's Avatar
Could be the fuel pressure regulator .
But can be anything else , check for spark and fuel pressure .
One way of checking the FPR is try cracking it with the fuel return hose off "Warning if it is working it will shoot fuel"
Old Jun 29, 2011 | 03:39 PM
microwave's Avatar
alternator
Old Dec 22, 2014 | 06:11 PM
Ralliarrrt's Avatar
Hey man I literally had the exact same thing happen to me this weekend I'm currently still working on it just wondering if you had any luck or found the problem. You'd save me a ton of time. I realize this post is from about 3 years ago but if anyone could help that's be great
Old Jan 7, 2015 | 10:52 PM
02modlanceroz's Avatar
Did your car die while driving or just won't start?
tsidrift1
Dec 26, 2015 01:49 PM
Dkvang920
Dec 12, 2015 09:58 AM
ziad
Jun 12, 2012 08:22 PM
EvoChemist
Dec 6, 2008 08:57 PM
Tommy boy
Dec 1, 2008 01:04 PM
