Should I Buy a Test Pipe?
Old Jan 1, 2004 | 01:41 AM
imapunkclaimer's Avatar
My main question is basically asking if a test pipe is worth the price and does it add any gains. I also want to know what kind of sounds this thing gives off because i dont need any exhaust sound. I mean does it sound like a $40 ebay exhaust or does it sound nice. Nothing too loud for the back. Im using stock exhaust all the way through and i have aem intake.
thanks.
Old Jan 1, 2004 | 03:16 AM
JVlancer's Avatar
tp is going to give you some gains... as for sound never heard it with stock exhaust... I have 2 in my shop sellin em for 50 each.. I have one with my greddy ... sounds hella deeeeep
Old Jan 3, 2004 | 12:09 AM
TypeIII's Avatar
Do you have any other modifications other than the CAI?
Old Jan 3, 2004 | 12:14 AM
nope, not yet. im saving up for turbo in the near future
Old Jan 3, 2004 | 12:34 AM
TypeIII's Avatar
Then just save your entire exhaust system until then. Makes more sense to do it that way, no?
Old Jan 3, 2004 | 12:40 AM
but will i need to redo my exhaust system when i go turbo?
Old Jan 3, 2004 | 12:53 AM
TypeIII's Avatar
You'll be in need of an exhaust manifold, which hopefully will eliminate your first catalytic converter... Then maybe at that point you'll just want to go with a high flow cat with 2 3/4" piping to the back, or run a straight pipe if you're constantly on race gas and on a race track?
Running this setup, at this point, will only hurt your performance.
Old Jan 3, 2004 | 12:56 AM
yea i figured, but is it ok to have stock exhaust with turbo?
Old Jan 3, 2004 | 12:57 AM
TURBOit's Avatar
test pipe is alright if your looking for cheap gains, or trying to squeeze every inch of HP you can get on a track, my car right now is wide open except for a resonator, its alright, lots of smoke, kinda smelly, im replacing the entire system with a 2.5" downpipe, 2.5" hi-flow cat, 2.5" catback w/ just a muffler, i also have the header, to me, as a turbo, this is the best and most ideal setup, hp gain b/w test pipe and hi flow are minimal
Old Jan 3, 2004 | 01:02 AM
thanks for the info. greatly appreciated. ill just be sticking to the worthwhile mods for now then
Old Jan 3, 2004 | 01:39 AM
gt40's Avatar
the stink is coming... seriously, consider a random tech cat etc instead. I ran a test pipe for 3 months and am going back to a cat.
Old Jan 3, 2004 | 02:02 AM
alright. im not big on exhausts either. I guess ill go stock for a while and maybe get some custom piping done later.
Old Jan 4, 2004 | 05:45 AM
JVlancer's Avatar
The only thing you may need to change is if you were to have a test pipe or cat, either or, the length of the downpipe rrms is made to fit the stock exhaust but if you were to get a longer downpipe ( like the one I have ) you would have to cut the TP a bit smaller I think the cat measures around 15 1/2 " Mine is a short TP i had to make 8" other than that thats the only modding of the exhaust that you would have to do as long as its a cat-back direct bolt on.
Old Jan 4, 2004 | 07:07 AM
cdyancey's Avatar
it will make you sound more high pitched......... keep the cash and save up for a high flow cat.
Old Jan 5, 2004 | 04:41 AM
JVlancer's Avatar
it will only make your car "high pitched" if you have a header, I have greddy exhaust and its so f'n deep it sounds purrfect
