Can i break 13s?
Old Jan 3, 2004 | 01:15 PM
NITROHEAD's Avatar
Can i break 13s?
Hey,
Im buying a RRM Intercooled Trubo kit and i was wondering what else i need to break 13s? If i buy new rods and pistons what PSI can i run every day? and what PSI i can run in a race? What other things should i get for my car to break into 13s?
Old Jan 3, 2004 | 01:18 PM
TURBOit's Avatar
id say 10 psi safely at least, rrm has their stage 2 which will come with a piggyback i believe, if you go with their stage 2, and do all of the usual bolt on upgrades, you coudl run 13s, i dont know if about lower, no one has gotten that far yet
Old Jan 3, 2004 | 08:11 PM
fkrzo's Avatar
Traction!!! Slicks and LSD, and a good launch.
Old Jan 3, 2004 | 08:16 PM
MarcioTheGreat's Avatar
A rocket tied to the roof and pointed in the right direction.
Old Jan 3, 2004 | 08:27 PM
TypeIII's Avatar
To reach 13's, 200whp and drag radial is pretty much all you're going to need. Limited slip helps, drag slicks help, better gearing definitely helps, and more power can never hurt.
Old Jan 3, 2004 | 11:34 PM
Drive02Lancer's Avatar
like posted above...traction...u can't go anywhere if ur burning rubber through the first 3 gears lol
after u get the turbo, larger throttle body, headers, full 3" turbo-back exhaust, and a L.S.D. and u should be good.
MAKE SURE YOU ARE GETTING ENOUGH FUEL TO THE ENGINE BEFORE YOU START BOOSTING TO HIGH!!!!! lol. you need more fuel the more you boost or you'll kill the engine, Hobie i believe had this problem when he put on a T3 turbo i think he had on his car.
Traction and Fuel will get u to where u want to go. I believe they said the turbo kit comes with a 255 lph fuel pump.
EvO_essence
22
Jun 2, 2016 03:54 PM
Wheatley
17
Jan 13, 2011 10:56 AM
senate6268
Lancer Aftermarket Forced Induction Tech
26
Mar 30, 2008 08:50 AM
RichEd223
22
Apr 20, 2007 10:28 AM
jxs1984
May 14, 2006 12:38 PM
