Help! With gas mileage problem. SRI/Oil Cap?
Old Jan 30, 2004 | 11:47 PM
Alchemist's Avatar
Somebody had a sig about getting shoes from a cement cobbler. I liked that quite a bit
Old Feb 4, 2004 | 01:10 AM
Satori's Avatar
Don't make sense. I got much improved mileage on my GS-T with a metal UICP and K&N FIPK in spite of the fact that I turned the boost up 3 psi over stock. I’d assume it’d be the same for Evo’s.
I bet you the ECU is expecting the soft intake to lower intake pressure. In that case, with a hard intake the ECU would be dumping too much fuel into the engine, making an already rich condition worse. I’d say, get a SAFC if you are going to use a hard intake instead of stock. See how much it helps.
Old Feb 4, 2004 | 10:28 AM
JohnMemorialHS's Avatar
Originally posted by urbanknight
This probably won't prove anything, but filling your tank to half and guaging how many miles to get to 1/4 is not accurate at all. When my guage gets to 1/2 I know I only have about 1/3 tank left.
I have noticed that our fuel gauge isn't accurate. I can fill it up to half a tank, and 10 min. of city driving, it goes to almost a quarter, then hop on the freeway, 10 min. later it goes in between 1/2 and 1/4.
Old Feb 4, 2004 | 11:02 AM
mylancees's Avatar
I noticed after installing my SRI i kept a light foot but for some reasone my gas pedal got really heavy and my MPG now suck
Old Mar 6, 2005 | 04:11 PM
tidal's Avatar
almost a year ago i put in a K&N stock filter... noticed a decent drop in fuel economy... might as well get that injen SRI I want if i'm gonna be paying for more gas I wanna HEAR it get burned!
Old Mar 6, 2005 | 06:16 PM
Shingen's Avatar
I don't think anyone has said this, but check your tire pressure in all of your tires. You might be running low... that could cause a decrease in your MPG.
Fox
Old Mar 6, 2005 | 06:24 PM
brentg07's Avatar
unless ur runnin at 5 psi it shouldnt make as big of difference as he is talkin, very true however that low psi will cause a small change in mpg. I say reset the ecu, I have the rrm short ram and when i installed it i noticed no change in my mpg.
MitsuSkot
Apr 9, 2016 05:39 PM
ImMikeTran
Lancer Engine Tech
Sep 8, 2006 01:44 PM
EVO316
South Region
34
Apr 20, 2006 01:07 AM
bigdoggy_dog
16
Dec 13, 2004 09:31 AM
thacollection
Nov 12, 2003 01:48 PM
