Es
Old Jul 28, 2002 | 08:37 AM
cincyracer2002's Avatar
Es!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
I know i didnt buy the best lancer out there i have an ES along with alot of other people, and i am sick of criticism and the lack of products, please help me rock make some stuff for the es also, and i catch greef for lowering my car with coil overs it was my only choice with the ES so have some consideration!
Old Jul 28, 2002 | 08:44 AM
freeflyng's Avatar
I believe most of the Road /// Race products will work for your ES, excluding the REAR ANTI-SWAY BAR. In fact I believe most of the products available will work for the ES. There really isn't much difference between the models. Is there?
Any one else have .02 on this?
Old Jul 28, 2002 | 08:48 AM
the eibach springs dont fit it, the lug pattern is different and there is some other stuff to like the sway bay u mentioned.
Old Jul 28, 2002 | 08:49 AM
freeflyng's Avatar
Oh yea, I forgot about the pro kit, after all I have it on my OZ and take it for granted...
Old Jul 28, 2002 | 08:55 AM
HobieKopek's Avatar
You have the same bolt pattern (4x100) as the Honda Civic and therefore more wheels available than just about any other bolt pattern. Definitely way more than the OZ.
As for the springs...get the OZ perches and the same springs will fit. You have the same front suspension as the current Mirages. Mitsubishi no doubt cut corners and saved money by using existing parts for production of the ES. It's not the end of the world, it's just annoying.
If you ***** and whine and complain and keep telling companies there's a market...they will come. Good luck.
Old Jul 28, 2002 | 12:43 PM
pjal84's Avatar
Alright let's see if I can clear things up a bit...
ALL engine related parts will fit between every trim of the Lancer.
The difference between the ES and the LS/OZ is the front suspension.
Read up here.
As for the RRM lower tie bar, the ES either has a) the mounts the LS/OZ has but without the bar installed, b) no mounts but the bolt in holes are present or c) (worst case) the ES doesn't have anywhere in the rear to bolt up the bar.
Old Jul 28, 2002 | 06:15 PM
my main complaint was people criticising me for doing the only thing possible to lower my car (the coil overs)
Old Jul 28, 2002 | 06:56 PM
cnile51's Avatar
anyone know how much oz perches cost and where tyo get em?
NiLe C.
Old Jul 28, 2002 | 07:14 PM
uranium9v's Avatar
Not too sure on the price, but you can get them from your dealer, as they end up putting them on if you get the RMR/ralliart set up.
