99-2000 mirage to a 2002 lancer??????
Old Oct 28, 2013 | 04:23 PM
tbugarin's Avatar
i want to buy coilover spring sleeves for a mirage and put it on my 02 lancer oz struts will it fit????
Old Oct 28, 2013 | 05:34 PM
Automatic 51's Avatar
https://www.evolutionm.net/forums/fo...play.php?f=182
Old Oct 28, 2013 | 06:42 PM
tbugarin's Avatar
Thisis what I had in mind
Old Oct 28, 2013 | 11:20 PM
Yeah, we understand what those pieces of crap look like. Read the thread that sub forum andee if your answer is in there and if not...post your question there.
Old Oct 29, 2013 | 12:50 PM
tbugarin's Avatar
i read the whole thing, but it doesn't mention anything about suspension. but it has been confirmed that mirage springs CANNOT fit on the oz/ralli struts/shocks.
Old Jan 2, 2014 | 03:33 AM
SilentCool's Avatar
I don't think those sleeves have a very good reputation. At least on most forums I frequent. Personally I haven't used them so I can't tell how they will perform but from reviews, there isn't much positive things being said about them. As for the fitment I am unsure. Have you already checked out the mirage compatibility thread?
Old Jan 2, 2014 | 03:40 AM
SilentCool's Avatar
Sorry, just seen that you already checked out the Mirage Compatibility thread. I say if you can't find much info there you might be better off with some ground control sleeves. Just a mild drop and you should be fine. That's if you need adjustability. If not and you're very short on cash the Tein S-Techs seem to work fine for many, the drop is mild - it's functional. I'm not sure what you're looking for but I hope whatever I mentioned helps.
Old Jan 2, 2014 | 09:58 AM
Thahomeboyb's Avatar
Don't buy cheap springs . You better off with going off the mid range prices. Quality over Quantity
Old Jan 9, 2014 | 12:12 AM
OZR_Lancer's Avatar
whatever u do, don't buy the sleeve springs thy are a total pos.. i know cause i had them on mine and took them off month later cause thy were causing damge to the car
All We'll Drive
Sep 8, 2011 01:59 AM
Mirage2.0
Lancer Engine Tech
Apr 5, 2010 09:08 AM
joberk3
Lancer-Mirage Compatibility Forum
61
Oct 12, 2009 11:34 AM
mirage 4g93t
10
Jul 22, 2009 04:15 PM
Racer24x
Dec 19, 2008 11:59 AM
