Blacked out headlights question?
Old May 4, 2004 | 04:37 PM
pgmike's Avatar
Could i use nite shades to paint the chrome part of the inside of my headlights instad of some paint?
Old May 4, 2004 | 05:03 PM
LooksFast's Avatar
night shades?
Old May 4, 2004 | 05:04 PM
pgmike's Avatar
sorry my bad, nite shades.
Old May 5, 2004 | 07:45 AM
NyteShadow70's Avatar
Why don't you just use paint? I did my headlights with high temp low gloss paint and they turned out great. Just spray about 5-6 coats, with about 20 minutes between coats. Its one cheap mod that makes my car better looking
Old May 5, 2004 | 12:51 PM
pgmike's Avatar
bc i want it to look glossy. anybody know if itll be able to handle the heat?
Old May 5, 2004 | 12:54 PM
Kurt's Avatar
Just get high temp gloss black. Sorry to jack your thread Mike, but can someone give me a suggestion why my passenger headlight won't quit fogging.
Old May 5, 2004 | 12:59 PM
CoronaLancer's Avatar
mike, use glossy black paint
kurt, you are going to have to bake or dry housing then reseal with silicon.
Old May 5, 2004 | 01:01 PM
pgmike's Avatar
how hard is it really to do the whole thing and how long does it take?
Old May 5, 2004 | 01:02 PM
Kurt's Avatar
done that three times already. I am tired of cleaning silicon out of the housing. Might buy a new one if I can't fix it and start from scratch.
Old May 5, 2004 | 01:03 PM
pgmike's Avatar
man the headlights are expensive unlike tails so hopefully you can fix it
Old May 5, 2004 | 01:07 PM
Kurt's Avatar
I hope so too. My wife is getting tired of me turning the kitchen into a workshop.
Old May 5, 2004 | 01:11 PM
Maybe yo should check the rubber housing around the sockets, make sure they arent cracked.
Old May 5, 2004 | 01:14 PM
LooksFast's Avatar
the whole process takes about 1 - 2 hours... at least it did for me
Old May 5, 2004 | 01:16 PM
pgmike's Avatar
ok thanks. how easy is it to mess up?
Old May 5, 2004 | 01:21 PM
Kurt's Avatar
Here is a list of things that I have checked:
1. Checked all seals, seals look fine.
2. Check the rubber gasket around the headlight socket, that looks fine.
3. Before taking it apart the last time, I submerged the headlight in water, I couldn't see a leak.
4. I have checked, and double checked my work before putting everything back together, everything looks fine.
My next step is to call my local Mitsubishi dealership and see what they suggest. I am going to tell them why warrenty is expired and my headlight is leaking, not telling that it has been taken apart, and see what they recommend. They will probably want me to bring it in, but it doesn't hurt to ask.
