Neon Pedals - How to?
Old May 29, 2004 | 04:24 PM
St-evo's Avatar
Question Neon Pedals - How to?
I just bought a set of those glowing pedals, and I have them almost completely installed, I just can't figure out how to hook them up to an electrical source so they will light up. Does anyone know how?
Old May 29, 2004 | 04:44 PM
SlowRyd's Avatar
Run you power lines for the pedals into the dash and then over to the center console. you can the splice the power wire with the power for the cig lighter and ground your neg to the chassis.
Old May 29, 2004 | 04:46 PM
SlowRyd's Avatar
you can add a switch in there somewhere if you want to be able to turn them off while you are driving. if not they will glow as long as the key is in the on position.
Hope that helped!
Old May 30, 2004 | 08:06 PM
LancerEvoMR's Avatar
Moving to USLG.
Old May 31, 2004 | 03:11 AM
Drive02Lancer's Avatar
i personally ran a power wire straight from the battery to a inline fuse than a switch...so i can turn my neons on anytime i want to. just gotta remember to turn em off, haha. and just ground to the chasis. just about any bolt will work just get a volt-meter and test em out.
Old May 31, 2004 | 02:00 PM
PitoPocket's Avatar
what color glow pedals can you can and where did you get them from??
Old Jun 2, 2004 | 12:49 PM
St-evo's Avatar
thanx guys, that helped, now its glowin real nice...
and pito - u can get them in almost any color, ive seen blue, which is what i have, red, green, yellow and even pink. they make them for both auto and manual, and u can get them at pretty much any autozone or pepboys. theyre not to expensive, only $30 and it comes with everything u need, the pedals (duh), all the wiring, and an on/off switch. pretty sweet deal.
Old Jun 2, 2004 | 12:56 PM
mcbrown35's Avatar
Just hook them into your parking or headlight fuse. no switch needed, never forget to turn them off... Buy a piggyback fuse holder which gives you a power lead and a fuse to protect your new lights... Buy at Autozone for $5...
