Where to tap the Lancer headlight power source
Old Aug 1, 2004 | 09:24 PM
initialDRacer's Avatar
Hi, I was wondering where the red and black wires are that goes to the steering column so I can tap it with a new gauge cluster Im installing. So the gauge is in-sync with the headlights when turning off or on. I can't seem to find it, there's so many wires down there and I don't want to splice every single one! Perhaps I can just tap it directly on the fuse box?
Old Aug 9, 2004 | 05:33 PM
h8yourv8's Avatar
Go directily for the fuse box. Personally I don't like cutting factory wires unless I have too
Old Aug 10, 2004 | 09:22 AM
Pick_a_Fro's Avatar
well...i'm curious, which gauge cluster u go for? If it's the reverse indiglo gauges, then u don't need to tap into the headlight source.
Wut I did was cut/splice the wires from the dimmer switch. It should be the GREEN/BLACK wire and the BLACK wire.
Old Aug 10, 2004 | 02:20 PM
I got the reverse indiglo gauges. I guess that's not a bad idea. You mean the GREEN/BLACK = POSITIVE and BLACK = NEGATIVE ??
Thanks for the response Let me try doing that.
