car plan
Old Aug 23, 2004 | 07:02 PM
03RallyLancer's Avatar
car plan
Hey guys, im a little bored so i thought i would post up my car build up plan and see what you all thought and if i perhaps i left anything out.
corner balance - 350
harness - 154
short shifter-ninos - 199
shifter link bushings-kartboy - 30
magnacor wires & plugs - 89 + plugs
grounding kit?
tb - 289
im - 349
pb - 439
finish exhaust - ?
motor mounts - 289
LSD - 890
clutch & pressure plate - 99 + 289
flywheel? - 489
Note: i am doing it this way to slowly build up the car so i can stay in the lower autox classes as long as possible.
after the tranny work i will probably go forced in the form of RRM turbo. So let me know what you think.
03
Old Aug 23, 2004 | 07:36 PM
ambystom01's Avatar
Sounds good, what do you mean by corner balance though?
Old Aug 23, 2004 | 07:38 PM
pgmike's Avatar
i would rethink:
grounding kit?
motor mounts - 289
LSD - 890
flywheel? - 489
Old Aug 24, 2004 | 04:35 PM
corner balance is to tune a coilover kit, lets you get the most out of your suspension
Originally Posted by pgmike
i would rethink:
grounding kit?
motor mounts - 289
LSD - 890
flywheel? - 489
why would you say that? i can understand the first 3 by why the last 4.
Old Aug 24, 2004 | 04:41 PM
lookslikeanevo's Avatar
i would probably do the clutch and PP, flywheel prolly not...lsd, are you really gonna be pushing that much power?...motor mounts i dunno cus its not like your gonna be launching you car
Old Aug 24, 2004 | 04:44 PM
actually i plan to take the car as far as possible and an lsd just doesnt help launching but in turns aswell
Old Aug 24, 2004 | 04:47 PM
ZooRacer's Avatar
TB and IM..u can get that done cheaper at a local shop!
Old Aug 24, 2004 | 07:36 PM
pgmike's Avatar
mtoro mounts are fora jumpy motor which you wont have with so little power so will jsut be a waste of money. the lsd may be a little useful but you arent going to produce too much power to make you spin your tires at a good rpm. i do not think you will ned to replace your stock clutch unless you do somre serious beating on it. flywheel may be a little helpful but minimal imo.
Old Aug 24, 2004 | 07:40 PM
ah but i am planning on boosting after tranny work though
edit: since i doubt i will do the tranny myself... i figure i will go ahead and get it all done at once
Old Aug 24, 2004 | 07:59 PM
pgmike's Avatar
well in that case, do gt that stuff, but not until you do go turbo and fidn that you need them.
Old Aug 24, 2004 | 08:01 PM
well it will cost more to get it done after... unless i decide to do it myself... b/c it would cost more to remove some of the turbo piping to get to the parts they need to get too.
Old Aug 24, 2004 | 08:07 PM
pgmike's Avatar
man the pipes take two seconds to take off, thats not really an issue.
