Spark plugs and wires install.
Take off the 4 10mm bolts holding down the coil packs. Unplug the 2 wires from them. Pull the coil packs up and off. Pull the wires up and off. Unscrew the plugs. Then do everything in backwards. Quite possibly the easiest change you can make on the Lancer.
You'll need to use a sparkplug socket (comes with most tool kits) and an extension to unscrew the sparkplugs themselves. And another thing to watch out for is when you're pulling the wires out, try not to tug on the wires themselves. Use the base of the wires so you don't damage them.
Originally Posted by gregivq
Hmmm I was just concerned because the guy that change my spark plugs used some kind of a tube to unscrew the plugs.
i know this thread is kind of old, but are these good plugs?
http://cgi.ebay.com/ebaymotors/ws/eB...category=33693
i don't know if its the same for auto but my 02 OZ takes the NGK BKR5E-11 and i put in the NGK BKR4E-11 in mine. It's the exact same plug just hotter. Stock Num 5424. They add little bit of power and i still haven't even done the wires yet.
FS[West]: Ralliart Spark Plug Wires OEM coil packs
fugiwara
18
Jan 2, 2017 06:24 AM
canyonkid
42
Sep 25, 2015 09:27 PM
