Lancer How To Requests / Questions / Tips If you have any questions, post them in here.
resealing tail lights
Old Jun 12, 2005 | 08:52 PM
jon_e_blaze's Avatar
i have the depo tail lights on my lancer. they have both got bad seals, and get alot of condensation inside. can anyone tell me how to take the covers off and reseal them?
Old Jun 12, 2005 | 09:12 PM
Z_Lancer_Man's Avatar
Try using a heat gun or your oven to soften the glue. Pry them apart and reseal. Also, you may have gotten water in them through another way other than the seal. Take out the taillight, remove all the light bulbs and leave the taillight in your house for 24 hours. Maybe speed up the drying out process using a hairdryer. This will eliminate any moisture still in the taillight.
Old Jun 12, 2005 | 10:45 PM
TeAmEmPeRoR's Avatar
after you try what Z Lancer Man suggested, I've also read peeps on here using aquarium silicone glue, or something like that to seal them up as well.
Old Jun 12, 2005 | 11:17 PM
Honni414's Avatar
couldnt you just put something over the existing seal without taking them apart?....i think it would be easier like that but im a newb so i dont know
Old Jun 17, 2005 | 04:54 PM
mitsuozboi's Avatar
I have the same problem, i have tyc tails and my driver side has leaked and builds nasty condensation. What if you just loosened it up and got some of that aqaurium glue and kinda spread it on the seal? then just pull a bulb and hit it with a hairdryer to dry it..
Old Jun 17, 2005 | 04:59 PM
ddubb's Avatar
one word...EVODAVE, he seems to be the master at headlight/taillight modification so send him a PM and he might be able to help you out.
Old Jun 17, 2005 | 10:11 PM
mitch44759's Avatar
I used RTD (silicone) just put it all around the edges and around some of the screw housing on my TYC no condensation since...
Old Jun 18, 2005 | 04:27 AM
Slovak's Avatar
+1
Old Jun 18, 2005 | 05:26 PM
mitsuozboi's Avatar
cool. mabey ill just try some simple silicone
Old Jun 18, 2005 | 09:54 PM
Honni414's Avatar
i went to autozone and picked up some windshield sealent and just went around my tail light with it and did a few layers where i knew the leak was and its great....no condensation at all.....it helped alot and was hella easy
LancerMM13
Lancer Engine Management / Tuning Forums
Feb 8, 2017 09:42 PM
jarred15801
Oct 22, 2013 09:53 AM
strtrcng426
Northeast Region
Sep 2, 2010 11:57 AM
gallas
Nov 20, 2009 10:18 PM
OtownEvo
Sep 24, 2007 01:54 AM
