please help me out
please help me out
ok i searched and cant find ... i just bought some stock evo recaros for freakin cheap ( $170 )... now i have to figure out where in the hell to find brackets for a good price... or if its possible to take the stock ones and use them on the recaros ... i have looked at them for about half an hour ... the recaros seem simple to remove the rails but the stock lancers are a different story... if someone can help by answering or directing me to where this has been discussed i would really appreciate it
... Thanks
... Thanks
well ok if i can just get the rails off then thats all i need to do i think ... but the problem is a screwdriver wont pry those rivets or whatever those things are that hold the slider rail on their
the evo seats with the stock sliders and brackets on their ... but im trying to see if i can use the lancer sliders on the evo ones ... cuz i cant seem to figure out if that will work or not ...
i tried to bolt on the passenger side directly...the two front bolts line up but the back dont at all ... so i guess im just going to have to buy brackets unless anyone else has any other bright ideas to help me out with
Originally Posted by SLVROZ_03
Let me get this right, you have the Evo seats but no sliders or brackets? You might be a good canidate for the RPW or RMR (forgetting which company) seat brackets.
http://www.rodmillenstore.com/produc...ategory=access
yea ive seen those ... but i found a local store that sells the brackets as well as the sliders for around the same price...i was just trying to find out if the lancer sliders would come out ... cuz i have to idea to take them out...i tried that how to on here but i cant get those rivets off
well im not being ungrateful ... all i said was they obviously dont bolt on directly since im asking about it on here ... i do remember reading here that they should be a direct swap but thats why im so confused because the rear bolts are so far off ...
well i know that the passenger side railing was bent a little by the door but it was easy to fix and i can see that the back bolts do not line up at all after i bolted the front two down ... plus the driver side didnt even have the parts that bolt down into the floor ...only the slide rails
