Lancer How To Requests / Questions / Tips If you have any questions, post them in here.
How do I remove vinyl decals
Old Apr 11, 2006 | 06:47 AM
Kurt's Avatar
I have been thinking about removing my Mitsu logos of my wing. How do I go about removing vinyl decals without screwing anything up.
This what I have now.
Also how do I go about removing the pin stripes?
Old Apr 11, 2006 | 10:42 AM
binsento's Avatar
use a hairdryer or heatgun to heat it up, then peel it off.
use some goo remover afterwards, then maybe wash and wax that part
Old Apr 11, 2006 | 11:02 AM
XTXANDY's Avatar
That pretty much covers it.. although I would wash before you try anything just to get the dirt and dust away and I would defiently wash and wax afterwards.
I'm a big fan of the 3M Adhesive remover (can be found at walmart). Works great but does strip the wax so always a good idea to wax afterwards.
Old Apr 11, 2006 | 11:03 AM
clangfor72's Avatar
I had the dealership decals on mine and I just pealed them off and then used Goo Gone, worked great and didn't harm the paint.
Old Apr 11, 2006 | 11:49 AM
Kurt's Avatar
Thanks. I take it that the pin stripes will come off the same way?
Old Apr 11, 2006 | 11:55 AM
Anarchy99's Avatar
3M sells a stripe remover that you put on a digrinder and it's like a big erasoer and will not hurt the panit at all can try that.
Old Apr 11, 2006 | 12:03 PM
clangfor72's Avatar
I haven't tried taking off pinstripe, but if you can peel it the Goo Gone will take off the stickey stuff.
Old Apr 11, 2006 | 12:30 PM
DemisedGabe's Avatar
gasoline or kerosine works good..
Old Apr 12, 2006 | 11:00 AM
Blacksheepdj's Avatar
Hot day and fingernails worked for me.
I de-riced my car in an afternoon at the drag strip (Buschur shootout - a DSM blew up on the track, so I had some time on my hands)...
Old Apr 12, 2006 | 11:16 AM
digdat's Avatar
The *best* way to remove vinyl is to use a steamer - like a handheld steamer you would use to get wrinkles out of your clothes. Just steam the decal and peel off (including the adhesive) in one pull. The cool thing about this is that you don't have to clean-up the adhesive afterwards
Second best is hair dryer and goo-gone or rubbing alcohol. The hair dryer will heatup the decal and you can pull it off. You will then have to clean-up the adhesive (glue) using goo-gone or rubbing alcohol.
Anarchy99
Oct 20, 2009 03:54 PM
ox663bender
Nov 30, 2005 08:21 AM
LancerPitcher49
Aug 15, 2005 07:55 PM
jk_addict
Mar 16, 2005 03:08 PM
lomax6
Oct 17, 2003 11:05 PM
