Battery Problems
Ok well i have to do a few things to my car in the next few days and it involves removing the battery from my car... see the problem is that i have the RRM piggyback installed also and if i remove the battery it will loose both of the settings that i have on them... so is there a way where i can keep the ecu and such alive while i remove the battery from the car?
Originally Posted by sykou
Just set another battery on the ground somewhere and connect it using jumper cables. Then remove the one under the hood and your good to go
no its because im disconnecting the battery to get to the transmission and under the battery for some wires im running. but i think the battery to battery with jumper cables will work excapt it might be hard unbolting the clamps with the jumpercable there.
I also heard of a way you hook the smaller 12V batterys you can by in the stores up to your DC outlet and it will somehow keep your cars power on? does this work? and where can i find one, bec. ive been looking for one now?
check on ebay they have setups that plug into your cig lighter and have a 9volt battery on the other end which will keep the ecu and the radio alive . . . but not for long from what ive heard.
SiliconTek
North Texas Evo Club (NTEC)
Feb 6, 2012 06:48 AM
