Lancer How To Requests / Questions / Tips If you have any questions, post them in here.
Accessory Belts Install!
Old Nov 5, 2006 | 08:00 PM
03whiteOZ's Avatar
Could someone please make a good how to with pictures on how to change the accessory belts? It would be a great help on general maintenance because there are no repair manuals for this car. Thanks!
Old Nov 6, 2006 | 06:57 AM
atilla's Avatar
that's power steering. loosen the tensioner bolt (48959K) inside the bracket there and you can pull the belt right off.
i wasn't able to find a picture of the alternator belt, if you want to do that one i might be able to go snap a few pictures of my lancer.
Old Nov 6, 2006 | 08:11 AM
03whiteOZ's Avatar
Awesome, thanks atilla, that is the kind of thing I'm looking for. I wonder why they haven't made a haynes manual for this car yet.. If you find the other one please post!
Old Nov 6, 2006 | 08:23 AM
atilla's Avatar
i can't find the other one in CAPS... it's like they don't even list the alternator belt. maybe i wasn't looking in the right section, heh.
there IS a manual for our car, but it's printed by an aussie company and so naturally it's not even for a US lancer.
anyway, i'll go out to the car and try to snap a few decent photos of the routing of my alternator belt. i've taken off the power steering and A/C belt maybe a thousand times in the past week. it's finally back to normal after i replaced some bolts on the tensioner that were screwed up.
Old Nov 6, 2006 | 08:35 AM
atilla's Avatar
okay, i snapped some photos... got a little washed out by the flash though.
release the tension on the belt with the tensioner:
then loop one end of your belt around the pulley on the alternator:
and then loop the other end around your crank pulley in the channels on the inside--you will need to remove your power steering belt to do this, so if you're replacing belts do this one before putting on a new power steering belt on.
Old Nov 6, 2006 | 07:24 PM
03whiteOZ's Avatar
Awesome man! You are alot of help! I really appreciate this!!
Old Nov 7, 2006 | 04:11 AM
atilla's Avatar
no problem, just make sure you get them tensioned down properly... that's one thing you can't show in pictures.
Old Nov 7, 2006 | 10:38 AM
grubiaco's Avatar
around what mileage do you guys change all the belts? Including your timing belt?
Old Nov 7, 2006 | 11:07 AM
crypto's Avatar
Former Vendor
60k
Old Nov 7, 2006 | 11:08 AM
Myszkewicz's Avatar
Depends on how much I drive. Back when I was driving 40,000 miles a year, I changed the accessory belts once a year, mostly so I never had to worry about how old they were getting.
Timing belts should be changed at whatever interval your owner's manual specifies. It varies state-by-state. I do mine every 60,000 miles.
And CAPS has the other belt, it's in 14-110. Doesn't show much, though, just a V-belt and two pulleys.
Old Nov 7, 2006 | 12:06 PM
grubiaco's Avatar
well I am at 55k. I was thinking about changing th timing belt at 80k along with the rest of the belts.
Ferp
Jul 20, 2017 02:48 PM
Evo_Goodness
Oct 17, 2016 04:24 PM
w evo
Sep 26, 2015 12:35 PM
cmiller10
Oct 10, 2014 08:04 AM
TommiM
Jul 8, 2009 07:32 PM
