**How to change your oil**
I didn't see a post up of a how-to-change-your-oil for US Lancer... so here it goes...
Here is my engine that we are changing the oil on
Here are the products that you will need: Mobil 1 Extended Performance Fully Synthetic Oil, K&N Oil filter, something to drain the oil into, a car jack and some jack stands (I like to use a ply-wood board to lay on and to keep the oil that doesn't make it into the pan from draining on my driveway).
After you put the car up on jacks, make sure to take off the oil cap to release the pressure.
This is the drain plug that is going to be removed to drain the oil
Now if you are like me, the drain plug wasn't real easy to just twist right out... I need to use a little more force
This is sometimes the only way to get a tough plug off... here is a comparison of the old plug and the new plug
Now the oil is finished draining out of your oil pan, you can unscrew the old oil filter
After taking out the drain plug and oil filter you will need to replace them with your new drain plug and K&N oil filter
Now pour your oil in the engine
Finally, put your oil cap back on, lower your car and you should be ready to roll for the next 15,000 miles!
RTV on your pan? you got leaks?
i wouldn't run the car for 15k between oil changes... a downside of those micro paper filters is that they can get clogged much quicker since the paper is so fine and the filter will go into bypass quicker.
you also need some power steering fluid.
grey fox: the plug is a 14mm.
Originally Posted by lancerman360
do you have problems with vta?
Originally Posted by zlancer
hey that turbo kit looks familiar! heheh that was the one i made!
https://www.evolutionm.net/forums/sh...d.php?t=226625
What the HELL were you doing?!
the red stuff looks just like the RTV silicone we put on cars when the gasket that is supposed to be somewhere gets FGFU.
Originally Posted by wickdaddy
I had never heard of that before... I have not had any issues with leaking from the pan.
