Lancer How To Requests / Questions / Tips If you have any questions, post them in here.
How To Install Rotors.. 04 Es
Old Apr 4, 2007 | 10:43 PM
04LancerChick's Avatar
I have a 2004 ES, and first I need to know
do we have a "Drum" or "Disc" on the back (So I know for when I buy the Rotors)
Also, how are they install. Step by step instructions would be nice.
THanks
Old Apr 5, 2007 | 01:24 PM
SLVROZ_03's Avatar
Whoa! If you had to ask what braking setup we have in the back, I'd let the pros do the front install... Just being honest here! But there should be a how-to in the Lancer section.
Good luck!
Old Apr 5, 2007 | 01:48 PM
kfos01's Avatar
The install is really easy. We just did mine about a month ago. You should definitley have someone around that kinda knows what they are doing, but the short and easy way of putting it is something like this.
1. Unbolt the caliper.
2. Take the old rotor off. (You may need to hit it from the backside with a rubber mallet. And turning your wheel while doing this helps a LOT!!)
3. Put the new rotor on tightly.
4. Replace caliper.
5. THIS IS THE MOST IMPORTANT PART!!! Make sure you replace all the bolts
6. Repeat for the other side.
I would suggest changing the pads if you have the $$. Then bed them in really well and enjoy!!
Like I said, this is just basically instructions for dummies. It's pretty simple, but it would be wise to have a buddy that knows what they are doing
P.S. We have drums in the back. You shouldn't have to replace those if you have an '04.
What kind of setup are you plannig on installing?
Old Apr 5, 2007 | 01:52 PM
LancerEVA06's Avatar
drums on back..... I hate drum brakes... 5 minutes to replace [disc] pads... 15 to replace shoes! hate em
Old Apr 5, 2007 | 01:57 PM
Well I needed to know if we had drums because when you go to liek Discount Auto Parts, they ask if we have Drums or Discs in the back so we know which to buy.
Seems pretty easy
I already changed the brakes maybe 2 weeks ago
Now I just need the Rotors done
but I'm changing the front brakes, I don't know why he asked about that. I figure before I even do anything, let me figure it out.
I didn't see anything in the "How Tos" section so I had to ask
Old Apr 5, 2007 | 06:04 PM
kfos01's Avatar
No there isn't a rotor install that I saw in the How-To. Good luck, it's pretty simple...just be safe!!
Let us know how it goes!
Old Apr 11, 2007 | 10:30 AM
Blacksheepdj's Avatar
I guess we should have taken pictures, huh?
ROCK
Lancer Vendor Classifieds
10
Mar 8, 2007 09:41 AM
ralliart 04 21
Dec 17, 2006 12:56 AM
04lancerEsGuy
Sep 3, 2005 01:04 PM
xtianLANCER04
Mar 5, 2005 02:48 AM
uranium9v
23
Feb 3, 2003 05:23 PM
