Lancer How To Requests / Questions / Tips If you have any questions, post them in here.
DEPO headlight problem
Old Apr 11, 2007 | 06:28 PM
EVOx2008's Avatar
Hello.
I sucessfully installed (plugged and attached) my right head light. upon testing the running, low, high beam and the turn signal i encountered a problem. My turn signal does not work and on the inside of my car when i have it on, it flashes/clicks (on the dash) at a normal speed for about 3-4 seconds then flashes/clicks much faster until i turned it off... is there anything i may be doing wrong?
i connected the following...
two small connectors on rear near turn signal
the lightbulb (which the black clip needed to be swapped for the depo one cuz stcok black ring didnt fit)
the screw and two bolts
the snap in peg.
any ideas as to what may be going on??
any input would help.
***MODS this may need to be moved to another section....***
thank you!
EVOx2008
Old Apr 11, 2007 | 06:55 PM
PGDlancer's Avatar
the increased blinking speed is just a safety feature that lets you know the turn signal is not working correctly..... so flip your signal on and go see if it's working.
Old Apr 11, 2007 | 07:05 PM
EVOx2008's Avatar
Hello, I turned the car on, attempted the 4-way emergency light, turned my turn signal on and no flashing, yet when i re-installed my stock headlight it worked fine..
is there turn signal bulbs not included with the headlights?
Old Apr 12, 2007 | 10:29 AM
atilla's Avatar
no bulbs are included with the depo headlights... i'm assuming you mean the black ones, right?
put your old bulbs in the new lights and you should be okay.
Old Apr 12, 2007 | 12:46 PM
EVOx2008's Avatar
now the bulb that is the high/low beam, i know that doesnt come with, (the once that you have the turn that black connector onto it... but the turn signal lights arent working..... :S
Old Apr 12, 2007 | 02:18 PM
SLVROZ_03's Avatar
Exactly, the head lamps come with no bulbs bud... Take the bulb/harness from the stock lamps, and put'um into the new one. These aren't Cedias are they?
Old Apr 12, 2007 | 03:38 PM
EVOx2008's Avatar
nope.... i got al three bulbs removed and added to the depo ones... will post some pics, and add a MORE detailed install/how to. they work great. thank you for your
help. it's greatly appreciated
Old Apr 12, 2007 | 04:31 PM
manny_fresh's Avatar
Check your connections. Im pretty sure something got bent and did not insert properly. i know from expericnece...same thing happened to me. Those lights do come with bulbs.
Old Apr 12, 2007 | 06:40 PM
SLVROZ_03's Avatar
The Lancer Depo headlamps come with their own bulbs? That's news...
Old Apr 12, 2007 | 07:01 PM
atilla's Avatar
mine didn't come with bulbs...
evox_4x4
Dec 20, 2015 09:42 AM
97 dsm 4g63
Aug 28, 2011 11:36 AM
Feyasco1031
Apr 11, 2010 07:00 PM
Luke18
Nov 2, 2009 05:39 AM
digdat
Lancer Troubleshooting
May 11, 2006 10:10 AM
