02 Lancer Depo Headlight Issue
Hey Guys
I just recieved my new 02 LANCER DEPO Projector headlights and Im having an issue
I cant seem to get my sidelights on Im guessing the driving light thats Amber
on the left and rightside
And my Turn signal on the driver side now blinks faster then the passenger side
Any help suggestion would be appreciated
Thanks in advance
Thanks in advance
hehe, I can add a voice to the groans. I am also having a problem with these lights (not exactly the same problem). The wiring with these lamps seem a bit.... how shall I say.... cheap ?
in terms of the light issues, i had a similar problem, unplug the turn signals and make sure that the prongs are lined up right so that they fir into the female end of the plug, mine weren't aligned right and they would blink faster than they were supposed to. and the driving light harness didn't clip into the male end like the others did, but i just made sure that it was all lit up then eletrical taped it together, and it seemed to work. hope any of this helps.
I had a fun time having to fix problems with the connectors on these headlights. I would say reuse the socket from your old headlights and the new bulbs might fix the problem. It might be a similar problem I had where the connectors aren't fully connecting.
I'm having the same problem with the connectors not going fully in, so I'm guessing is not making full contact with the connectors. I was thinking about cutting a bit of each plug so it can go in properly and might solve the problem, what do you guys think?
doncarbone
42
Apr 24, 2016 08:32 AM
