Lancer How To Requests / Questions / Tips If you have any questions, post them in here.
Hid??
Old May 15, 2007 | 12:56 AM
csiplon's Avatar
Hid??
Are there any HID kits compatible with our car available?
Old May 15, 2007 | 06:55 AM
Hawkeye's Avatar
Well I doubt there are any kits that are for the specific model as of yet, but I'm looking at some other kits that I've used previously to see if one (or two) is going to work well.
Old May 15, 2007 | 12:42 PM
Wallesasuaz's Avatar
yea man... There's always HID kits available. Remember they are plug and play.
not sure if we run a 9006 or 9007. But we can figure that one out.
The only snag you'll run into is the fact that these cars come w/ automatic day-time running lights. You would have to bypass that in order to keep your lights from being turned on at all times.
Old May 15, 2007 | 03:56 PM
jRox's Avatar
is there anything wrong with having HID lights on at all times?
Old May 15, 2007 | 04:07 PM
There's nothing wrong w/ it.. but why would you want your lights on during the day. Especially on a nice hot summer day?
The only thing wrong w/ it, really, would be that the lifetime of the bulb will be reduced due to it being turned on all the time.
Old May 15, 2007 | 05:41 PM
jRox's Avatar
^^ oohhh, i forgot about that. i think the bulbs lifetime is like 2500 hrs. anyway, if anyone figures out how to disable the daytime-lights, LET ME KNOW
Old May 16, 2007 | 07:16 AM
Hawkeye's Avatar
Also the DRL system runs the lowbeam lamps at lower intensity. This is done by lowering and regulating the power sent to the lowbeam system. If you put HIDs on this, there's a good chance that the lower power signal being received by the ballasts may damage them.
Keep an eye on this. I'm tracing the entire DRL system and working on a workaround to either disable them completely or move them to the highbeams (like the 2000-2003 Chevy Impala.)
Old May 18, 2007 | 01:31 PM
whitelancerGTS's Avatar
Old May 18, 2007 | 01:46 PM
Okay.. that's nice.
Now tell us one thing... did you bypass the DRL's?
don't post a pic and write no text.
thanks
Old May 18, 2007 | 01:51 PM
Hawkeye's Avatar
That looks good but I'm still worried about the DRLs.
Old May 18, 2007 | 02:20 PM
EvoRhodeIsland's Avatar
Cut the wires......did it om my old dodge ram....
Old May 18, 2007 | 02:33 PM
Hawkeye's Avatar
That's the thing, there's no wire to cut! In my post on the other HID thread this is what I've come up with:
Pulling the DRL fuse doesn't make the DRLs cut off.
There is no relay that I can find.
Still only two wires are running into the lowbeam lamps - positive and ground. Which means the voltage is regulated elsewhere, probably the ECU. There's really not a wire to cut.
Old May 18, 2007 | 02:47 PM
i have more pix at my cardomain page. sign the guest book!
http://www.cardomain.com/ride/2625776
Old May 18, 2007 | 02:48 PM
regarding the wiring. i basically switched the fog lights with my day time running lights.
any more questions?
here are some more pix.
took these photos with my phone. sry if its blurry.
Old May 18, 2007 | 02:50 PM
Hawkeye's Avatar
Yeah one more question.
Writeup on how to switch the DRLs? Even with how you did it that's further than I've gotten.
