Lancer How To Requests / Questions / Tips If you have any questions, post them in here.
Intercooled vs Non intercooled
Old May 30, 2007 | 12:28 PM
xLancerOZx's Avatar
whats the difference between these two?. Hopefully sometime around this year im gonna turbo my 02 lancer O-Z and i want to know which is better.
Old May 30, 2007 | 12:38 PM
mitsuozboi's Avatar
do a search man... seriously. search forced induction section. tons of info on this..
Basically... Intercooling is better. turbo gets cooler air which meens, a lot more power. It will also run cooler.
Old May 30, 2007 | 01:45 PM
Coolguy949's Avatar
It all depends on the size of the turbo. If it's running low on the efficiency map then the turbo wont heat up much at all. Intercoolers bring the inlet air temp down to near ambient temp.
Some turbo kits do not benefit much from an intercooler, and the added lag isn't worth it. It all depends on the characteristics of the turbo and how much boost you will be running.
Old May 30, 2007 | 01:48 PM
boostinpsi's Avatar
intercooler cools the air after the turbo and before it enters the TB. Colder air means denser air means more fuel means more power and less prone to knock that kills motors.
i would never own a turbo car without an intercooler.
Old May 31, 2007 | 06:38 AM
xLancerOZx's Avatar
I have read about just every thing on the reg lancers at school and i have never seen someone ask this. If they did im sorry
Old May 31, 2007 | 06:44 AM
alan678's Avatar
+1
Old May 31, 2007 | 10:39 AM
SLVROZ_03's Avatar
Yeah, though cars can and do run w/o an ic...I'd never run one like that. EVER!
Old May 31, 2007 | 05:59 PM
iufan4lifeul's Avatar
With an intercooler you generally lose 1-2 PSI in the actual core of the intercooler. This is made up by air that is much cooler. Imagine a hot summer day vs. a cool night and how much better the car feels when it is cooler. Now multiply that by a few times and that is what an intercooler is doing.
Old May 31, 2007 | 06:18 PM
ambystom01's Avatar
This is a basic tenant of turbocharging (or forced induction in general), no one has asked it here (at least not in it's own thread) in some time because the answer can be found in 30 seconds using a google search. An intercooler lowers the temperature of the intake charge which results in more power. On a car like the lancer where the engine is weak from the factory I would not recommend turbocharging without using an intercooler.
Old May 31, 2007 | 06:23 PM
Evo_Jr's Avatar
NEWB!!
You asked whats the difference between Intercooled, and NON.
Lancers don't come turboed so why just stop searching on a NON turboed car.
Search around forums, and read! Many members on here are turboed, and have both. Non and intercooled. Compare. Stop being LAZY!
This has been everywhere, even RRM show a HP increase on their Intercooled kits over their NON. Why, ummm common sense. Maybe more boost? Call them, they are GREAT costumer service!
Oh by the way, Welcome. I'm David
Old May 31, 2007 | 06:43 PM
kungfugirl's Avatar
i have non ic and i regulate my knock and egt temps on my widband.
i live in socal and i have dry heat that gets to about 105 and i have had zero issues, some power loss when its hott but that is normal.
and evojr, wtf are u talking about in your post?
Old May 31, 2007 | 07:04 PM
Evo_Jr's Avatar
I'm not even going to bother. NEWbs can't seem to use the search buttom
Old May 31, 2007 | 07:07 PM
kungfugirl's Avatar
no they cant, but im just asking you to make your post at least understanable.
Old May 31, 2007 | 08:00 PM
xLancerOZx's Avatar
uh. i did search a little bit in google and non gave a clear answer... the reason i asked this cause while some people on here have the non-IC and some with the intercooled...
Old May 31, 2007 | 08:04 PM
ambystom01's Avatar
Really, cause I don't even need to research this topic and I found a useful article right away. http://en.wikipedia.org/wiki/Intercooler
