Lancer How To Requests / Questions / Tips If you have any questions, post them in here.
How to: RRM SRI install
Old Nov 7, 2007 | 07:57 PM
nj_08_gts's Avatar
Originally Posted by Nosman
RRM SRI comes with a K&N filter ?
No.
Old Nov 8, 2007 | 10:16 AM
Blacksheepdj's Avatar
Originally Posted by james51685
have you noticed a difference and do you feel it was worth it
~jimmy
Yes, I noticed a good difference in power. It was definitely worth it.
No, that was a mistake. Fixing it now.
Old Nov 13, 2007 | 02:18 PM
08GTSMayhem's Avatar
Thanks for the directions, I installed mine today and it really took no time at all (10 minutes or so)
I hear the intake which sounds cool but at a certain RPM, around 2500 it makes a kind of weird sound before sounding good again. Is that normal or do I have a leak maybe? Also, the part where the filter fits on is quite long is the filter supposed to be towards the end of it or as far down on it as possible?
Old Nov 13, 2007 | 03:06 PM
nj_08_gts's Avatar
It's normal...the intake sounds a little anemic around that 2500 RPM mark.
The filter should go down as far as you can get it.
Old Dec 13, 2007 | 03:47 PM
I never got to thank the reply. At first the intake sound was a little weird but I think once I got used to it, I really like it. I don't know it seems like my car has "gotten used to it" as well. It's quite different now then it was when I first installed it.
Old Dec 14, 2007 | 10:40 AM
Yeah, modern cars do have a "learning period." Good to hear you're liking it.
Old Feb 9, 2008 | 11:49 PM
ashun22panda's Avatar
do we have to get the SRI from RRM to install the
http://www.roadracemotorsports.com/s...oducts_id=222?
or can we just get the intake and install it?
Old Feb 10, 2008 | 11:57 AM
I'm a little confused by your question, so I'll give two answers.
If you want to just buy this and nothing else, no, that won't work. There'd be nothing to attach it to.
If you're asking if you have to buy this and this, then no, you don't need to. You only really need to buy the "Replacement filter" item once your original one has gotten dirty or damaged.
Old Mar 5, 2008 | 10:33 AM
LuDa's Avatar
lancers are so weird..if i understand correctly
a SRI gives just as much a gain as the injen CAI correct?
Old Mar 6, 2008 | 11:21 AM
Yes, that's about right.
Old Mar 20, 2008 | 09:06 PM
bigredlancer08's Avatar
anyone else get a CEL after installing the SRI? i had a diagnostic run on it and it says im running lean on bank one, and its most likely my MAF sensor.
Old Mar 21, 2008 | 07:57 AM
Double check that the MAF is plugged in securely and bolted down tightly? 90% of the time, it's install error.
You have a Fed-spec, so I can't figure why it'd be so sensitive to the intake...
Old Mar 21, 2008 | 10:10 AM
thanks. i checked it out this morning again, and everything was in right, then i reset the ECU and it was fine. *slaps self on forehead* thanks though!
Old Mar 21, 2008 | 10:29 AM
Give it time, it can come back after driving a bit. Or maybe something was a hair loose and the problem's fixed. It's hard to say.
Old Jun 15, 2008 | 02:23 AM
3.9tt's Avatar
anyone try the new RRM Short Ram intake? the polished aluminum one? wanna know if theirs any differance between the two besides it's prettier looks.
