Lancer How To Requests / Questions / Tips If you have any questions, post them in here.
Dont Want Too Much Rice in my Diet!!
Old Jul 10, 2007 | 02:14 PM
08Lancer89's Avatar
no
Old Jul 10, 2007 | 02:19 PM
03evo**'s Avatar
doit blue man...
Old Jul 10, 2007 | 02:20 PM
03evo**'s Avatar
actually get the chrome paint...
Old Jul 11, 2007 | 05:08 AM
Eagles GTS's Avatar
You will need high heat primer, high heat paint (gunmetal lol) and high heat clear coat. Make sure you clean the covers very well. That is important for long lasting paint.
Old Jul 11, 2007 | 05:28 AM
08Lancer89's Avatar
I did not use any high heat piant all I used was paint for plastic, and it worked fine I went on the freeway the other day doing 90 when I stoped to get gas I checked if it was okay and it was, high heat paint is not required!
Old Jul 11, 2007 | 01:58 PM
graypearlgts's Avatar
Chrome??? sounds a little rice to me... can someone paint shop that to see what chrome would look like?
anyway, so plastic paint would work and has some lasting power but the way to go is high temp paints...
Old Jul 11, 2007 | 03:31 PM
08Lancer89's Avatar
I dont think its Necessary....at all
Old Jul 11, 2007 | 03:55 PM
Eagles GTS's Avatar
You might change your mind in a few months. It might start to peel or chip. The price difference is so small, there is no reason not to pay an extra $5 for the high heat just to be safe. Time will tell.
Old Jul 11, 2007 | 05:30 PM
08Lancer89's Avatar
fine with me, Like I said before I did 90 on the freeway for 30min then got gas and check the paint and it was fine, I let it dry 24hrs before I did this........
Old Jul 11, 2007 | 08:40 PM
Rabidhamster's Avatar
normal automotive quality paint is fine.. doesn't have to be high temp (aka 800+F etc) unless it's exhaust
the main reason non "high heat" paint under hood fails is purely the prep or lack there of, you can spray your block with the same automotive paint macco uses in it's $99 paintjob and as long as the block was prepped properly the paint will stay probably longer then the paint on the car.
covers... again prep is the main part.. and you can rattle can covers AS LONG AS THEY ARE PREPPED RIGHT. prep is 99.999999999999999999999999% of the quality of the finish.. the rest can be reworked after it's laid down without totally starting over.
Old Jul 12, 2007 | 05:38 AM
08Lancer89's Avatar
I sanded mine a bit even tho the paint said I did not have to then I put 3 small coats and after that dired I put one more thicker coat, then I let it sit off the car and in my room for 24hrs.... I did a lot of prep
Old Jul 15, 2007 | 11:09 AM
JohnnyMuyo's Avatar
If you asked me before the pics about painting the cover teal, I would have said no, but after seeing it, I'm surprised how well it turned out. It's a nice accent to the engine bay. The red looks great, too.
Old Jul 15, 2007 | 06:42 PM
08Lancer89's Avatar
thanks!
ozrallyrace
May 5, 2011 11:28 AM
Tree
13
Jan 9, 2008 06:06 PM
08Lancer89
47
Sep 7, 2007 12:08 PM
PaganImmolator
Mar 29, 2006 08:25 AM
hbruce16
May 19, 2005 04:16 PM
