Lancer How To Requests / Questions / Tips If you have any questions, post them in here.
Do i need to replace gasket if i remove valve cover??
Old May 2, 2011 | 08:11 PM
ozrallyrace's Avatar
im planning on removing my valve cover on my 2006 lancer oz so that i can paint it (chrome purple!!), and i wanted to know if i have to replace my gasket or anything or if i can just simply take it off, paint it, and put it back on. If anyone has tips or suggestions on painting and removing a valve cover, any help would be greatly appreciated. thanks!
ps. i tried doing some research on my gasket question but i couldnt find anything..maybe im blind i dont know
Old May 3, 2011 | 12:57 AM
Midnightkid's Avatar
Anytime you open anything up like the valve cover, then you're better off replacing the gasket. You'd be risking it not to. As for painting, take your time during the sanding process to make sure the paint has a good base to stick to. If not, you'll find yourself starting all over again.
Old May 5, 2011 | 10:55 AM
tempest1130's Avatar
x2 it's better to be safe then sorry
Old May 5, 2011 | 11:20 AM
steven121's Avatar
I never changed mine and it leaked oil during boost I tightened it down even more which fixed the.problem but here is something to remember if you take off a gasket replace it never reuse. I'm about to change mine soon.
Old May 5, 2011 | 11:28 AM
SyZyGy1394's Avatar
A lot of times you can actually reuse a gasket. Mainly depends on the type of gasket, condition of the gasket, condition of mating surfaces.
Evo_Goodness
Dec 19, 2020 02:39 PM
djslik408
Jul 26, 2017 06:32 PM
SLVRNBLK
Mar 18, 2016 10:19 AM
erald01
Feb 20, 2011 07:17 PM
72charger
Lancer Engine Tech
Mar 22, 2006 09:55 PM
