Gaskets Needed when doing cams???
Old Feb 20, 2011 | 12:42 PM
erald01's Avatar
Havent done this in a while, but when installing cams which gaskets are needed?? As far as i remember: Valve Cover gasket, spark plug gaskets, cam shaft seal....is there anything else???
Old Feb 20, 2011 | 02:59 PM
erald01's Avatar
No one has done any cam swaps???
Old Feb 20, 2011 | 03:00 PM
evo8426's Avatar
i dont recall any of my gaskets being replaced when i had cams put in a month ago
Old Feb 20, 2011 | 03:10 PM
06RedRalli's Avatar
Same here...just had my cams changed and didn't touch any of the gaskets...
Old Feb 20, 2011 | 03:33 PM
anthonyrb98's Avatar
i thought you have to change the valve cover gasket every time you remove it?
Old Feb 20, 2011 | 03:48 PM
blknblubkrdude's Avatar
I didn't replace any gaskets during my cam install.
The OEM VC gasket set is pretty high quality. I had no leaks after reinstall.
If you want a resealed valve cover, go to mitsubishiparts.net and get: MD340535 + MD186785 (x4)
Good luck!
Old Feb 20, 2011 | 05:14 PM
C6C6CH3vo's Avatar
Change them if needed. I have never changed the cam seals
Old Feb 20, 2011 | 05:27 PM
erald01's Avatar
thanx guys, I already had cams on mine when i got, but i am doing my boy's cams, but from DSM days i remember having to change the VC gasket, spark plug gaskets and the little half circle gasket that you had to put on the head.
Old Feb 20, 2011 | 07:04 PM
heel2toe's Avatar
You dont have to replace any of the gaskets unless they are ripped or in poor condition. My valve cover has been over numerous times and I only replaced it once because it has a slight rip. Just remember to apply a little RTV over the half moon shaped regions for a proper seal
Old Feb 20, 2011 | 07:17 PM
han's Avatar
han
i would recommend to change the cam seals, just in case
Black_EVO_MR
Nov 9, 2016 05:10 PM
17579EVO9MR
13
Oct 26, 2010 12:53 PM
coolnick
15
Feb 15, 2009 07:52 PM
ries
Aug 22, 2006 06:07 AM
GoEVOGo
Sep 26, 2003 11:45 AM
