Lancer How To Requests / Questions / Tips If you have any questions, post them in here.
help, IM missing a tube?
Old Jul 10, 2007 | 02:30 PM
CRSmoak's Avatar
Unhappy IM install, help
so yea, i just installed a new IM and the CEL came on so I looked around for what it could be and noticed that there was a tube missing. I took some things apart again and tryed looking for it but could not find it. you can see in the pic attached what i meen. so i was wondering if someone could post up some closeup pics of theres.
thanks,
Old Jul 10, 2007 | 02:52 PM
Shingen's Avatar
What's a tube?
Old Jul 10, 2007 | 03:18 PM
SLVROZ_03's Avatar
^ Vac line/ tube...
Old Jul 10, 2007 | 06:48 PM
CRSmoak's Avatar
sorry, ment vacuum line.
Old Jul 11, 2007 | 05:18 PM
CRSmoak's Avatar
i already tried going to the dealership and they didn't know sh**, so i would really appreciate it if someone could please help me out here
Old Jul 11, 2007 | 05:22 PM
Shingen's Avatar
Take your car to autozone. Ask to use the OBDII sensor. Go to your car pull the code. Get the printout from inside the store. Come back and tells us what the code says. I mean, that's what I would do.
I wish I could help more but without knowing why you're throwing a code then I can't really help. And the pic doesn't really tell me much, espcially since I'm using a 4g93 IM now. Oh, and take a wider pic of your engine bay... perhaps that will help us figure out what's not connected.
Fox
Old Jul 11, 2007 | 07:37 PM
kungfugirl's Avatar
Answer:
Does it look like it had one (answer: yes)
Is your car acting different now? (answer: yes)
Yes, i think you are missing one.
Old Jul 11, 2007 | 07:46 PM
CRSmoak's Avatar
I actually already went to autozone, the code # was P0455 which is an EVAP leak.
It says probable causes are
1. loose or missing fuel cap, which is not the problem
2. evap canister broke, hose cracked or not connected
3. Purge or vent solenoid defective
4. Vacuum leak at engine
Im pretty sure the problem is the vac line missing in the pic.
Old Jul 11, 2007 | 08:43 PM
CRSmoak's Avatar
here some more pics
Attached Thumbnails help, IM missing a tube?-004.jpg   help, IM missing a tube?-007.jpg   help, IM missing a tube?-013.jpg   help, IM missing a tube?-016.jpg   help, IM missing a tube?-017.jpg
Old Jul 11, 2007 | 08:49 PM
CRSmoak's Avatar
I put a circle around all the pics were one end of the vac line should go, I just can't find were the other end would go.
Old Jul 11, 2007 | 09:10 PM
atilla's Avatar
i THINK that is the evap purge solenoid... i may be wrong though. the line should be connected somewhere on the IM if i remember correctly. i think it was somewhere underneath the fuel rail where it was connected. i'd go check my car if it wasn't midnight and pouring rain outside. i will see if i can get a good look at it tomorrow.
Old Jul 11, 2007 | 09:13 PM
02-Lancer-Es's Avatar
this is what i saw, that should be connected to a long tube that goes under the car, looks to me like fuel line because before it goes under the car it connects to a metal tube
Old Jul 11, 2007 | 09:30 PM
CRSmoak's Avatar
alright well tommorow i will look some more by the fuel lines and jack the car up to see what I can find from under the car. Also if you could post a pic tommorow or when ever you have time, that would probably really help
thanks,
Old Jul 11, 2007 | 09:43 PM
thanks,
you dont really have to jack it up ,it connects under the intake piping to a metal line
Old Jul 12, 2007 | 07:44 PM
CRSmoak's Avatar
well i found the the metal line and hooked it up, started the car and no more CEL. anyway thanks a lot man, really appreciate it!
