Lancer How To Requests / Questions / Tips If you have any questions, post them in here.
Another Light Question, Xenon Bulbs
Old Sep 12, 2007 | 09:10 AM
DoHBoY's Avatar
Through my searching ive now come across a set of StreetGlow Xenon Bulbs as a possibility (considering they are only $30 for a pair, cheap cheap). They are rated at both 100w and 55w. So my question is:
Will our stock harness/wires be able to handle 100w bulbs or will i be forced to get the 55w?
Old Sep 12, 2007 | 09:52 AM
theblue's Avatar
if you read it again you'll likely find it's the usual market to ricers trick. they are probably 55w bulbs that they claim "have the appearance of 100w" which is total BS. In reality they are probably standard bulbs coated to have a cool color which in reality cuts down light output. Xenon looks also has no advantage, they're just saying they look like cars that come with xenon (HID) bulbs.
you'll almost never find true higher wattage bulbs because they would just fry your harness on most stock cars.
you might want to consider either a real HID kit or getting a proper upgraded headlight harness and looking for some real higher wattage bulbs.
Old Sep 12, 2007 | 10:21 AM
Blacksheepdj's Avatar
Does it sound "too good to be true?"
Then it probably is . . .
backwoodsRUNNER
13
May 24, 2012 08:15 PM
Au2Tek
Evo 'For Sale' Exterior Styling
Sep 24, 2011 09:54 PM
awdordie
Jul 4, 2011 09:07 PM
netracer
Mar 1, 2010 08:42 AM
hadeswolf
13
May 31, 2008 02:48 PM
