Lancer How To Requests / Questions / Tips If you have any questions, post them in here.
How To: Spring install
Old Jun 13, 2008 | 08:25 PM
MyPoison1's Avatar
Originally Posted by Karan
Ok I just had the springs installed today. Finally. Really love the look. It doesnt look "slammed" or crude. Looks like this is how it should've come from the factory. Has a really sporty 'OEM' look to it.
Anyhow, how long should I wait for the springs to settle, before taking it for alignment?
No pix of before and after?
Old Jun 13, 2008 | 10:07 PM
Karan's Avatar
Not yet. I will in a few days. Car is pretty filthy right now. Also going to give it a couple days atleast for the springs to settle.
Old Jun 13, 2008 | 10:26 PM
Protostar1's Avatar
Nice pics. In addition if you dont have an impact wrench (or you have a **** one), grab a breaker bar or standard rachet and put a piece of metal tubing (plumbing stuff gets the job done), that is a great way to break bolts. I have a huge Roush quick jack and I just use the handle, works wonders .
As for the cutting of the bump stops... not only can you cut them without modifying the dust boot, odds are you should do it regardless of your spring set up. As shown in my sig, I have a set of Swifts which give a reasonably modest drop in height, yet still require you to cut the stops. With a band saw and some sand paper its a pretty easy job...
Old Jun 13, 2008 | 10:28 PM
Protostar1's Avatar
Ive heard the generally accepted value is a week...
Old Aug 24, 2008 | 10:18 AM
08Lancer89's Avatar
anyplace were I can find a RRM Spring install how to?
Old Sep 9, 2008 | 06:08 AM
thebigt's Avatar
hey black sheep can i see some pictures of the car before the springs and after the springs i want to see the height difference before i make my decision.... especially from the back end. thanks
Old Feb 11, 2009 | 06:18 AM
charroncp's Avatar
I have a couple questions. If i drop my 2009 lancer 1.2 inch in the front and 0.8 inch in the rear, will i need to replace the struts? Also, will doing this void the warranty? If yes, will it void the entire warranty or just anything to do with suspension?
Old Feb 11, 2009 | 06:26 AM
EngRWW33's Avatar
It will put more stress on your struts which will make them go faster... but you will not need to replace them right away.
This will only void the warranty if the springs cause the problem, e.g. if you blow your struts warranty will not cover.
Old Feb 11, 2009 | 06:55 AM
charroncp's Avatar
Thanks for the quick reply, appreciate it.
Old Mar 16, 2009 | 05:54 AM
humblehyper's Avatar
It would be very nice for new beginner if there's an arrow in the pictures pointing on which one to remove, loosen, pull etc , other than that great DIY.
Old Mar 24, 2009 | 10:57 AM
charroncp's Avatar
How long did this take you to do yourself?
Old May 30, 2009 | 03:08 PM
SirLancerlotWPG's Avatar
I've seen some videos online, I think from RRM explaining how to do this aswell.
Old Oct 2, 2009 | 10:22 AM
djslik408's Avatar
RRM has video posted online. Im actually doing this today!
Old Oct 7, 2009 | 07:11 AM
08GTSLancerBlue's Avatar
pics
So I guess no pics?
Old Oct 7, 2009 | 09:47 PM
djslik408's Avatar
If I get home early tomorrow, I'll take pics. Its too dark right now and Ive been working late trying to get some extra OT!!!
