How To Make Windows Slide Auto. ?
its all run through the etacs-ecu like said before. Unless someone can program it in...I don't think mitsu can. So well unless you want to completely by-pass the etacs-ecu then I wouldn't bother. Actually I wouldn't bother at all, way too much work for a window for me.
Its all in the switch panel on the drivers door
Tis easy
You need two of these to do all four or one to do just the front:
http://www.audio-discounters.com/530t.html
One for up and one for down. Both get installed in the drivers door and it works like a charm. Can even integrate into some aftermarket alarm systems.
I have had mine doing it for a year now and not one problem.
Does the passanger get to do auto up and down with their switch?
