Lancer How To Requests / Questions / Tips If you have any questions, post them in here.
under the seat plug
Old Jan 4, 2010 | 01:50 PM
kadykady's Avatar
under the seat plug
Hi, I noticed that there is a wire and a plug that's not connected to anything under the 2 front seats, is that for the heated seat option? the wires look very thin for a heater circuit!
Old Jan 4, 2010 | 01:57 PM
EvoNyMR136's Avatar
there for your seatbelts. it just makes the light go away when u aint wearing ur belt
Old Jan 4, 2010 | 02:05 PM
kadykady's Avatar
the plug is not connected to anything, + plus I have it on both seats while I only have sea tbelt warning on the driver's seat
Old Jan 8, 2010 | 05:50 AM
tuf-vrx's Avatar
have the same in the gts still unsure as to what these plugs do lol
Old Jan 8, 2010 | 10:16 AM
EngRWW33's Avatar
Old Jan 8, 2010 | 10:18 PM
CamShaft's Avatar
It is probably for heated seats, you were correct. The wiring for heated seats doesn't have to be that thick since its only a 12V system.
Old Feb 10, 2010 | 05:43 PM
kadykady's Avatar
it's the other way round, heat = watt = Volts x Amps, so on a low voltage system (12 volts) you would need high current which means thicker cable.
Old Feb 10, 2010 | 05:51 PM
vetboss's Avatar
better hope it aint for your airbag
RA11226
Evo X How Tos / Installations
120
Jun 24, 2022 03:19 AM
Dailyevox09
Jan 3, 2014 03:26 PM
projektevo9
Sep 3, 2013 05:33 PM
Ev0_J0e
Jul 12, 2010 02:30 PM
Enkrypter_DJ
Lancer How Tos / Installations
Jul 30, 2007 03:27 PM
