Lancer How To Requests / Questions / Tips If you have any questions, post them in here.
"Debadging"
Old May 5, 2008 | 12:56 AM
a1rtunr's Avatar
"Debadging"
Newbie here wanting to know the quickest n easiest, pain-free way of de-badging the rear of the lancer. I am planning to debadge everything and installing the big "LANCER" nameplate from the 03' model.
Old May 5, 2008 | 05:33 AM
sgand's Avatar
Wait for a hot day or use a heat gun. Some use floss, I think I did, and then goo gone to clean up the sticky stuff.
Old May 5, 2008 | 05:35 AM
4bangn's Avatar
^^^ what he said
Old May 5, 2008 | 05:38 AM
stanrc's Avatar
i used fishing line and some goo gone to get mine off. they came of pretty easily. just be sure to wash the area after so the goo gone doesn't sit on the paint for too long.
Old May 5, 2008 | 05:41 AM
SamT83's Avatar
It's pretty easy, even easier if you do it when it's hot out. The badges are attached with an adhesive, so when it's hot, the adhesive loosens its grip a bit. If it's not hot outside, you can always hit it with a hair-dryer or a heat gun. Anyway, after it's been warmed up a little, grab some fishing line or some floss, something like that, and kinda slide it behind the letters and then make your way through the gummy adhesive. Sometimes it will come right off, sometimes you might need a little elbow grease and some of the sticky stuff will be left on the paint. If that happens, it's no big deal, just hit it with some Goo-Gone or even a rag with dish soap. It should come off. Another heads up, if you're thinking of preserving the badges for any reason, be particularly gentle. I got the "Mitsubishi" off in one piece on my car, but the "Lancer" broke off between some of the letters.
Karnage541
40
May 28, 2014 07:04 AM
jtkwok
Lancer How Tos / Installations
Nov 13, 2008 10:52 AM
spartanhelios
93
Aug 27, 2007 09:09 AM
SterlingEvo
Mid-Atlantic Region
Sep 24, 2004 12:25 AM
STC
May 29, 2003 10:34 PM
