Any Ideas on How to get Rid of this
Using a buffer makes it a lot easier. Hard to do by hand but it is possible. I hope everyone is wet sanding and NOT dry sanding. You will save yourself a lot of time and headache in the end.
By sanding your headlight you are removing the thin plastic-like coating that the factory coats the headlights with. So when you sand watch carefully and you can see it. You want to try and get all of this off because this is what oxidizes over time. good luck!
um you can also just wet sand with like 1200 or 2000 and then after that just get some of this and rub it on the lights with your hand... you dont need a buffer or anything... it takes like 5 min...
