Lancer How To Requests / Questions / Tips If you have any questions, post them in here.
Neon Lights help
Old Jun 26, 2008 | 07:34 AM
pascalc6's Avatar
Neon Lights help
Hey guys, i'm trying to install neon lights underneath the car and they say to drill. So i undercoated the bolts, undercoated the areas i wanted to drill but when it came time to drill. I could'nt, the metal is damn near impossible to drill through, even a shop could'nt do it. anyone have any alternatives to drilling which theyve done or special bits i should look into if drillings the only way?
Thanks
Old Jun 26, 2008 | 07:42 AM
Kurt's Avatar
They make drill bits just for drilling into metal.
Old Jun 26, 2008 | 07:50 AM
blood89's Avatar
i had the same problem on my cavalier so i used zip ties lol they where very strong ones i got at home depot lol they worked great and if u want to take them off there is no holes in your car.
Old Jun 26, 2008 | 08:03 AM
alloutDSM's Avatar
+1 on zip ties if you dont mind losing a light here and there.......
Old Jun 26, 2008 | 08:10 AM
pascalc6's Avatar
yeah, that was my next plan. Only problem is there isn't any holes close to the side to attach them. Only holes are about 4 inchs from the side and are onto a piece that sticks out abit. So they would be even lower then normally :S Always an idea though, thanks.
Old Jun 26, 2008 | 12:23 PM
yitzac1990's Avatar
theyre called "self-tapping screws"
Old Jun 28, 2008 | 05:49 PM
Sofla GTS's Avatar
awhhhhh i was gonna say that =( lol
Old Jun 28, 2008 | 05:55 PM
bluebyu36's Avatar
Old Jun 28, 2008 | 05:56 PM
Walkingchaos's Avatar
if a bit wont cut in a self tapping screw will just spin. start your holes using a much smaller size bit then move up to the size you need .
Old Jun 30, 2008 | 03:17 PM
RedStar's Avatar
if you are talking about the metal where you use the jack to lift it than i drilled my holes in there. All you have to do is really put some muscle into it and push your drill hard so it gets in there and than it should just come together. I must say it is a pain but its worth it =)
josh_evo9
Jun 20, 2014 06:14 PM
JDMEVO206
Northwest Region
Jun 16, 2014 03:57 PM
PaperClip
Nov 25, 2009 11:44 AM
ThUnDeRRalliart
04-06 Lancer Ralliart How To Requests / Questions / Tips
Feb 14, 2009 09:09 AM
