Lancer How To Requests / Questions / Tips If you have any questions, post them in here.
Exhaust question
Old Oct 9, 2008 | 02:05 PM
bakajudoka's Avatar
Exhaust question
I was planning on getting the Magnaflow Stainless Catback Exhaust on RRM's website, but a friend told me I could achieve the same result by just buying a highflow cat, because the tube would not be bigger enough to make a difference. Is he right? That would save me a lot of money, but it almost seems too easy . I drive a 2002 Lancer OZ Rally, and the only mod I've done so far was a short ram intake. Any help is appreciated!
Old Oct 9, 2008 | 02:11 PM
ambystom01's Avatar
Since you're new to lancers, I suggest you start by reading the FAQ linked in my sig, it has a lot of info for you. Your friend is partly right. You'll gain the same amount with a high flow as with a full catback because you won't gain a thing anyways.
Old Oct 9, 2008 | 02:31 PM
Juan Martinez's Avatar
Doesn't really matter. Unless you plan to go turbo, the exhaust either way will probably give you the same hp. Hardly any at all really. I would probably go with header first and a high flow cat, not a test pipe. Get a DOT approved one. After that, you should decide on cat back or just a muffler. Depends on how pretty you want your car to be under it.
Old Oct 9, 2008 | 02:44 PM
bakajudoka's Avatar
After reading this and the FAQ, looks like it's time to save up for a turbo.
thisonecountz
Apr 27, 2011 06:33 PM
dolphin888
May 9, 2010 07:12 PM
WickedIXMR
Mid-Atlantic Region
30
Mar 13, 2009 10:38 AM
blk03evolution8
Dec 13, 2008 11:50 AM
CrackaBoi
Jul 8, 2008 12:23 PM
