Lancer How To Requests / Questions / Tips If you have any questions, post them in here.
fog light wiring question
Old Dec 22, 2008 | 07:47 AM
madrex26's Avatar
Trying to install PIAA 1400x fogs on 02 lancer
2 fogs are connected to the relay. From the relay there are four wires, 1 for main power, 1 for ground (both connected to battery) and 2 to the switch. From the switch there is an extra wire that requires me to connect to a switched power (+) using a supplied vampire clip.
They recommend parking lights, but since this is the Mrs. car I dont know where it is or where to begin.
Where is the best/easiest place to tap into a switched power (+) wire inside the cabin?
Thanks for the help
