Lancer How To Requests / Questions / Tips If you have any questions, post them in here.
2008 Lancer shift point
Old May 16, 2009 | 10:11 AM
absolute's Avatar
^ yea i dont have a problem doing it, shifter + knob is stock too
werid :O
Old May 16, 2009 | 12:39 PM
Infamous_pt4's Avatar
werid :O
you'll have to show me how you do it at a meet cuz i cant get it to go
Old May 16, 2009 | 10:22 PM
I Am God's Avatar
technically i should be hard with a short shifter cuz u dont have the leverage on the pivot point like u do wit stock shifter.., but im wondering if its on some cars and not others..im thinkin its maybe sumtin to do with the rrm crank shaft pulley( = faster rotation) that me n infamous got, but u dont absolute....donno jus throwin it out there shoot me down if it doesnt make sense..
Old May 16, 2009 | 10:25 PM
^ true im just going by what i have heard from others , i think its just harder to do on some then others tho i could do it no problem when i had my sentra then i got this and nope
Old May 16, 2009 | 10:26 PM
I Am God's Avatar
^ bump..i jus edited my last post lol, what u think?
Old May 16, 2009 | 10:31 PM
^ i think he does have the pulley , it could make sense but when i test drove the car in all stock form i had a young guy with me and he let me do a burnout and it wouldnt do it then either , maybe the trans wont let you do it so you have to force it into second gear , its bothered me from day one cuz i cant keep my revs up from 1st to 2nd
Old May 16, 2009 | 10:35 PM
glad to see you american guys have the same problem too , our ecu's are different so who knows what else is different on the car
Old May 16, 2009 | 10:40 PM
I Am God's Avatar
lol, do u guys have differenct emission standards? i dont think theres nething else country-specific that would warrant a different ecu
if u get a weighted knob it should help..my knob that i got from TWM is 4 times the weight of the stock, it should help with the momentum when shifting so it engages easier
Old May 16, 2009 | 10:51 PM
^ naw our emissions are the same as yours with the acception of cali , but our ecu's are different , mods dont show gains very quickly and i believe a guy up here in montreal bought the rrm turbo kit installed it , and the car kept going into limp mode , later to find our ecu's are different , mitsu has already admitted it , we had a dyno shoot out between aem injen and works and lets jus say the ecus messed things up for that one
Old May 17, 2009 | 12:41 AM
Sparx123's Avatar
hmm i dont seem to have that problem of the RPMs dropping too low when i redline 1st gear
however it does drop lower than the rest of the gears cuz of the gear ratios, but it's usually above 4000rpmor higher @ second gear when i redline first
i like rip it into gear though, dun take my foot entirely off the throttle just touching it just a tad when im switching and i just switch as fast as i can...havnt grinded but i've heard my tires chirp (stock tires...my falkens dont really chirp when i do that) when i go from 1st to second
My car does the same as yours absolute... That's actually what I've been trying to explain in this thread...
I can't power shift either... I find if I don't use the clutch I have to let the rpm's drop about 1-1.5k and then I can just slide it right into the next gear...
Why would they change the ecu's between canada and the usa if cali's the only place with higher emission standards?
Old May 17, 2009 | 12:40 PM
I Am God's Avatar
what do u mean if u dont use the clutch? like after u hit redline and start to shift u stop half way and reengage the clutch while its in neutral then go to 2nd?
Old May 17, 2009 | 04:58 PM
dunno why the ecu's are different but they are its been admitted by mitsu and it makes no ****ing sense at all
Old May 17, 2009 | 05:03 PM
so i tested the shifting today to see the rpms drop and i was kinda in shock , i never took my eye off the guage from first to second i shifted as quick as i possibily could and at 6500 i shifted which is redline and the rpms dropped to 4 on the spot so thats a 2500 drop in rpms , but first to second is the only one that drops that much , every other gear is within 1k mark , but atleast is stays in the 4k range which is where the power is
Old May 17, 2009 | 05:59 PM
Sparx123's Avatar
What I meant was when I pull it out or gear without a clutch and to just slide it into gear without the clutch I've got to wait about 1-1.5k then it will slide in like butter...
Old May 17, 2009 | 06:02 PM
MrMeaner's Avatar
Double clutch, then it won't matter so much. Plus, easier on the car.
