Lancer How To Requests / Questions / Tips If you have any questions, post them in here.
Request: How to replace a radiator??
Old May 25, 2009 | 09:23 PM
Onkar02's Avatar
i have a punctured radiator and i need to know detail instructions on how to replace it because i dont want to have someone else doo it. i know its an easy job i just need a little bit more info thank you.
Old Jun 10, 2009 | 10:16 PM
Juan Martinez's Avatar
Well, its alittle late, basicly, you take off the bottom hose and let it drain out into a pan. Take off the top hose and top mount pieces. Unhook the trans coolant line. Just lift out the radiator. Unbolt the fans and relocate to new one, reverse everthing. Put in new coolant. Its really easy after you drain it.
Old Jun 11, 2009 | 04:53 AM
blaze_125's Avatar
After you put everything back toget, you gotta drain the air out.
Pour in your coolant, don't fully close the rad cap open the bleeder and start your car.
Periodically check the coolant level by removing the rad cap and add some as needed. When you get a steady stream coming out of the bleeder, close the bleeder, top off the rad, tighten the rad cap and you're set.
Old Jul 15, 2009 | 10:09 PM
Onkar02's Avatar
thanks guys i appreciate it
deadhead
26
May 16, 2017 11:24 AM
Boostfarmer
Nov 19, 2012 09:34 AM
ogrenator
Aug 20, 2012 01:11 PM
sykou
Lancer Aftermarket Forced Induction Tech
15
Mar 20, 2010 04:06 PM
talentsearch301
Jul 11, 2009 04:20 PM
