Sponsored by:
Sponsored by: CARiD
Radiator Hose Question
Old Aug 19, 2012 | 01:05 PM
ogrenator's Avatar
Hey guys,
I have a radiator hose kit to replace the stock rubber piping. I know I need to drain the radiator from underneath before replacinght the piping. My question is what if I only do the top two pipes, will I need to drain the antifreeze? Or can I just wait till its cold and replace them? Thanks in advance...
Old Aug 19, 2012 | 01:47 PM
quicksevo's Avatar
It's still going to leak no matter what..you also don't have to drain the coolant from the drain plug on the radiator, it will just spill a bit. If you don't want it to spill in the engine bay then remove the drain plug. Then install hoses and refill
Old Aug 19, 2012 | 08:31 PM
ogrenator's Avatar
did you try actually undoing the top hoses before draining? I know there will be some leftover fluid butare the top hoses always filled or only when the motor is being cooled?
Old Aug 19, 2012 | 08:45 PM
Johnr352's Avatar
As I understand it, filled
Old Aug 20, 2012 | 12:53 AM
quicksevo's Avatar
It's always filled
Old Aug 20, 2012 | 05:20 AM
ogrenator's Avatar
Fack...lol ok dudes thanks I figured as much but was hoping there was an outside chance it settled when not in use...looks like there wont be any shortcuts here
Old Aug 20, 2012 | 01:11 PM
ikt's Avatar
ikt
its only going to spill like a quart or so...make sure your engine is cool
TxFAkuma
Sep 4, 2015 02:34 PM
sternevo8
Mar 23, 2012 09:30 AM
sykou
Lancer Aftermarket Forced Induction Tech
15
Mar 20, 2010 04:06 PM
justchil
Dec 30, 2008 02:43 PM
lbcevo
Oct 5, 2006 08:40 PM
