Lancer How To Requests / Questions / Tips If you have any questions, post them in here.
Where to mount HID Harness
Old Jun 12, 2009 | 07:40 AM
anbuzero's Avatar
hey everyone been a while since i installed my hids and at the time i was rushing so i just ziptied the harnesses onto the frame rite next to the lights (i removed the black plastic long ago). Just wondering where everyone else mounted theres and if its a safe and secure spot. thanx in advance.
Old Jun 12, 2009 | 07:43 AM
LancerEVA06's Avatar
Take the front bumper off and bolt them to something. This is how I've always installed HID ballasts.
Old Jun 12, 2009 | 07:58 AM
three29's Avatar
i used industrial strength mounting tape, one is on the battery on the right side, and the other is on my window washer fluid container i believe. I have slim digital balasts by the way
Old Jun 12, 2009 | 08:02 AM
While I know that tape is strong, I would advise against it. Eventually it will work it's way loose, you'll hit a bump and the ballast will smack off something around it, then lose your light. All electrical components should be secured using screws, bolts, nuts, etc.
Just letting you know... I've seen many ballasts fail because the tape did.
Old Jun 12, 2009 | 08:08 AM
three29's Avatar
yeah i heard about that.. i had it done in a shop and i asked about it, but they said that it depends on what kind you are using. its been 2 years and theyre still fine. The consistancy of the mouting tape is almost like the glue that they use to badge our cars (if youve ever debadged our car you know what i mean)
but you are right shud be very careful u could break your ballast from a hard knock
Old Jun 15, 2009 | 05:36 AM
anbuzero's Avatar
thanx for your answers guys. i also have slim ballasts and i would like to take the bumper off and install them somewhere hidden but also comes the problem of having to do this every time something has to be fixed or changed with the lights.
while looking at the engine bay i thought about making a few custom pieces out of sheet metal to mount the harness on. if any one else has a different setup please post im open to other ideas
Old Jun 15, 2009 | 08:02 AM
02-Lancer-Es's Avatar
I actually do Hids alot of Hids and i mount the Ballasts for the 08 Lancer behind the bottom bumper fog light grills . Very easy to remove .
Old Jun 15, 2009 | 03:01 PM
kalpakiotis's Avatar
I mounted three of them underneath where the battery sits. Theres some holes there and i used some hardware and zipties to hold them in place. Then I have two ziptied to the frame on the otherside of the engine bay with the third one infront of the radiator. I found a hole there and mounted it to that with some zipties around it to keep it from moving. Looking in, you would never know that they where there. I also have all three relays in a project box under the battery mount to keep excess moisture from getting to them.
Old Jun 15, 2009 | 04:55 PM
evo_soul's Avatar
anywhere is fine. As long as the kit is shielded you wont run into electrical problems. I was bold enough to mount on my ECU. lol
Old Jun 15, 2009 | 06:15 PM
anbuzero's Avatar
thanx for the pics but bro u need a engine bay clean very very badly
Old Jun 16, 2009 | 01:48 AM
+1111111, how the hell is the engine bay that bad anyway? My 93 doesn't even look that bad, and I dont think I've cleaned it since 2003.
Norpothos
Lancer How Tos / Installations
Sep 15, 2015 05:40 AM
Evoracing47
Sep 21, 2014 06:49 PM
ekinshuya
Aug 7, 2014 04:48 PM
lookitznite
Apr 30, 2010 08:03 AM
heSOshAdy
22
Jun 24, 2007 04:22 PM
