High idle>?
hey guys and gals...quick question, im having a high RPM and its throwin me a CEL. i replaced the iac valve and motor and still gettin the same code. i was thinkin next is either the throttle position sensor or the fuel reg....any opinions?? help is appreciated, also if i would go with the TPS, any suggestions on the easiest way to get it out, its pretty cramped back there behiind the throttle body, thanks,,,
I would imagine there would be a code related to the tps as well if it was the culprit.
Try these solutions:
A vacuum leak
Leaking air intake after the throttle body
EGR valve leaking vacuum
A faulty positive crankcase ventilation (PCV) valve
Damaged/failed/dirty throttle body
Failed EVAP system
A vacuum leak
Failed EVAP system
I'm getting this same code. i had my throttle cable kind of pinched in a weird way, positioned it differently and now its idling perfect. i also replaced the IACV and I dont think it was necessary because of the throttle cable being tweaked.
