Lancer How To Requests / Questions / Tips If you have any questions, post them in here.
Advice on suspension
Old Nov 18, 2010 | 08:13 AM
lilmac789's Avatar
I got an 09 ES lancer and am getting tired of the stock suspension any advice?????
Old Nov 18, 2010 | 11:14 AM
evo_soul's Avatar
Quality Coilovers
The question you have to ask yourself is how much are you willing to pay. Alot of people buy the cheapest coilovesr they can find, and suffer as a result.
1) getting one that either doesnt have the range of features they need.
2) doesnt ride they want it to or makes noise
3) doesnt last long after a good North American weather cycle.
So do research, get feedback and buy one that everyone has good experience with.
Old Nov 18, 2010 | 12:55 PM
M@verik's Avatar
BC coilovers are quite cheap and pretty good. Ive got them.
Old Nov 18, 2010 | 02:49 PM
Sendo's Avatar
Lightbulb
Get coilovers if you plan to autox if not stick with lowering springs and a good set of shocks for easier street driving, to me its not worth the money to get real coilovers unless you autox or drift where it really matters just because they are adjustable doesn't mean they are better then lowering springs.
Old Nov 18, 2010 | 04:57 PM
lilmac789's Avatar
Thnxs guys!!
Old Nov 18, 2010 | 06:02 PM
evo_soul's Avatar
On the surface its good advice, but I disagree and I will tell you why.
1) Mitsubishi's specs for the strut. Ride height and valving does not take very well to Lowering with springs. Ad to that North American weather and you have a strut that will degrade rather quickly in terms of its performance and overall life.
2) The cost of installing the springs isnt terrible, but spring install and alignment isnt cheap either. If you go this route you run a very high risk of strut failure as you drive you car. This varies depending on many factors. But I cant tell you how many guys in our club have had their Struts warrantied or just replaced on their own dime because the strut failed. Primarily because of aftermarket springs.
I dont say this to discourage people from buying Springs.... I am just saying specifically for the Lancer GTS, Springs are hard on the strut. That said, a mild drop is worth it. H&R springs are a good balance, Eibach is even a little less of a drop than that.
The main point is. You get good coilovers.
$1600 installed and done. You will have suspension that operates at 100% all the time. Vs. driving on springs, with compromised struts. Your handling suffers and at the end of the day. That difference means you just avoided an accident instead of going into the ditch or losing control.
If you do the cost analysis of both... factoring the potential of replacing a strut down the road. Coilovers are the better way to go.
Old Nov 18, 2010 | 06:47 PM
Sendo's Avatar
True that's why I said get a good set of shocks, shocks are struts like how rims and wheels are the same thing lol I think you misunderstood their I don't recommend you drive on the OEM shocks/struts with any lowering springs.
If you run a good set of shocks/struts you shouldn't have any problems with lowering springs plus the stiffer the shocks/struts the better your handling would be too and don't get oem after-market shocks/struts replacements.
Lowering springs are hard on the oem shocks/struts that's why you also want to upgrade them when you put on lowering springs.
With a good set of lowering springs and shocks/struts your suspension/handling could be a lot better then coil-overs since they're at a set stiffness and spring rate they're just not adjustable so if you go to the track often and want to make adjustments coil-overs would be better. Coil-overs are by no means more "sturdy" then lowering springs they are just as prone to failure as much as lowering springs or shocks/struts. Broken sleeves, strut, brackets, perch etc.. can happen with coil-overs look at this thread for an example the coil-overs were made by HKS a very reputable company also prone to failure.
http://g35driver.com/forums/brakes-s...ch-snaped.html
Replacing a shock/strut with spring is still cheaper then replacing a whole new coil-over unit.
Its all on how you plan on using your car, track car or just cruising around the street just weight your options and goals they both have pro's and con's.
Old Nov 18, 2010 | 07:08 PM
evo_soul's Avatar
You are correct, I did not understand your response the first pass. lol Tired.... worked my second 12 hour day in a row
zTwitch
May 31, 2016 07:21 PM
nukleus
Oct 28, 2015 03:30 PM
88_Pathy
Jan 28, 2015 03:06 PM
visyoual
16
Aug 9, 2009 03:12 PM
Fifty
04-06 Lancer Ralliart How To Requests / Questions / Tips
12
Sep 27, 2007 08:16 AM
