Lancer How To Requests / Questions / Tips If you have any questions, post them in here.
The green fluid
Old Jul 8, 2011 | 08:07 PM
Huaje's Avatar
Originally Posted by chucknasty
prestone is green. in some cars it is true you have to use a special coolant, just not as many as you think. Part of it is true, part of it is ripping you off for money. But, my mitsu v6 eclipse i use prestone, the 4 cylinder eclipse uses prestone, and i know quite a few evo owners using it. The alochol/water mixture makes it corrosive, not enough alcohol usually. that's why i buy the full gallon, take an empty prestone container pour half in there and fill both with water. done.
Would you tell where I can find green prestone? In many years looking at the stores I have found yellow and orange prestone only.
Old Sep 14, 2011 | 10:17 PM
Hille's Avatar
Years ago there was just ethylene glycol antifreeze and it was green/yellow.
Now days there are so many (*$#^@(#*& choices and warnings not to mix them. Arrrrgggggghhhh.
Old Sep 14, 2011 | 10:28 PM
LancerEVA06's Avatar
If you have the green stuff in now... it's about 95% the same as the Prestone stuff. I worked at a Mitsu dealer... the techs would always top off/replace with Prestone unless the customer specifically asked for the DiaQueen.
And also, the DiaQueen we stocked on the shelves was 4year/100,000miles.
Old Sep 15, 2011 | 08:42 AM
chucknasty's Avatar
new prestone i by is always green. i have 4 gallons of it sitting in my shed right now lol. i buy the 100% antifreeze, if you are in an area that never goes below -15 you can do 30/70 and make 3 gallons for a little more than the price of one.
Old Sep 15, 2011 | 10:05 PM
The new Prestone is more of a yellow-green. Compare it to the real green stuff, you'll be able to tell a difference.
kyoo
220
Dec 11, 2018 01:32 PM
cangri1788
Lancer Engine Tech
Oct 20, 2014 09:56 AM
4b11ftw
Aug 6, 2013 01:14 PM
dRifT iT
Mar 25, 2012 03:56 PM
EvolNinja
11
Feb 26, 2009 09:33 PM
