Lancer How To Requests / Questions / Tips If you have any questions, post them in here.
Alternator pivot bolt nut...
Old Mar 17, 2012 | 06:28 PM
Havoc86's Avatar
I'm installing a new timing belt in my 2002 Lancer and I'm stuck on the alternator. I'm trying to loosen the nut on the pivot bolt but am having a very hard time. Not sure if it's a 14mm or 15mm. It seems like it's in between and my attempts are starting to wear down the nut. Before I mess up the nut completely, what's the best way to handle this situation? Any tips would help. If I do strip the nut, what's the best way to remove it? Thanks.
Old Mar 17, 2012 | 07:22 PM
corndog17's Avatar
14mm righty tighty, lefty loosey. I know because had to loosen my altenator to get to the crank position sensor. shouldnt be on too tight. Use a 3/ wrench.
Old Mar 17, 2012 | 08:17 PM
Havoc86's Avatar
I'll try it again but that sucker just won't budge.
Old Mar 18, 2012 | 07:44 AM
eusgen's Avatar
get the car raised up high enough where you can use a metal bar or a breaker bar and get some leverage in there!
Old Mar 18, 2012 | 11:16 PM
Havoc86's Avatar
Got it loose! Thanks guys
Hiboost
Evo X How Tos / Installations
16
Feb 27, 2016 03:33 PM
rodent
52
Aug 5, 2012 05:35 PM
saytheb
May 31, 2012 11:27 PM
stryfetew
12
Dec 9, 2007 07:49 AM
N1te
Oct 4, 2006 02:51 PM
