Lancer How To Requests / Questions / Tips If you have any questions, post them in here.
Crankshaft pulley bolt
Old Mar 18, 2012 | 11:25 PM
Havoc86's Avatar
I hope I'm not annoying people with all my questions...
Alright so I'm changing my timing belt and I've been stuck on the crankshaft pulley bolt. I don't really have any special tools. Just the basics.
I'm trying my best to loosen the bolt but I can't get it to budge. I have no air powered tools or breaker bars. Pretty much my first time doing this. I have heard of clicking the engine on while jamming a breaker bar but I want to avoid that option.
I'm looking for some tips. Any help will go a long way.
Old Mar 18, 2012 | 11:57 PM
jujukiller's Avatar
a breaker bar is 20 dollars go get one.
Old Mar 19, 2012 | 06:42 AM
eusgen's Avatar
This ^ or get a pipe that will fit your existing wrench for more LEVERAGE, you need more leverage!!
Old Mar 19, 2012 | 08:40 AM
Havoc86's Avatar
Found a cheap priced one...now the only problem that exists is the crankshaft pulley keeps turning on me
Old Mar 19, 2012 | 09:00 AM
corndog17's Avatar
get a large flat pry bar and your going to need to wedge it inbetween the flywheel and the bellhousing to make the crankshaft pulley stay in place. You may have to hold on to the pry bar at the same time your pushing down on the wrench to prevent it from coming loose when breaking the bolt.
Old Mar 19, 2012 | 03:49 PM
02modlanceroz's Avatar
put the car in gear and have a friend hold the brake pedal in while you crank the bolt loose.
Old Mar 19, 2012 | 10:40 PM
03lances's Avatar
^^ This is going to be the best way without worry about damaging anything
onix175
Lancer Engine Tech
Feb 19, 2016 04:54 AM
turbolancer02
Lancer Engine Tech
Jun 6, 2012 04:13 PM
Zman15
May 11, 2010 12:41 PM
anthonypazsd
Jan 31, 2010 03:01 AM
KevOVIII
18
Nov 10, 2005 08:05 AM
