Lancer How To Requests / Questions / Tips If you have any questions, post them in here.
Dash Gauge lights not working
Old Apr 18, 2012 | 11:11 AM
Montreal's Avatar
hey guys,
I have a 2003 lancer ES and my dash lights slowly got dim in the last couple of days then completely went out yesterday. all the other lights work like the turning signals, headlights, taillights, low oil, low gas,etc except for the gauges. I checked the fuses under the steering wheel and they were all fine. I also checked the wires attached and the ground wires but they both seemed to be ok. Also the lights that say P,R,N,D,1,2 are off to. and made sure the dimmer is at its brightest and still nothing.
ANY SUGGESTIONS?
Old Apr 18, 2012 | 09:14 PM
CrAnSwIcK's Avatar
re-check fuses, i'll have a peak through the diagrams tomorrow morning if no one answers by then...
Old Apr 19, 2012 | 03:25 AM
Montreal's Avatar
ok I will, thanks alot
Old Apr 19, 2012 | 05:45 AM
CrAnSwIcK's Avatar
check if your tail lights and rear license plate lights work...if not, replace fuse #21 in the relay box under the hood, they are on the same circuit...i know you said the tail lights work, but just verify fuse 21 is not blown...
Old Apr 19, 2012 | 12:29 PM
Montreal's Avatar
I looked again and replaced it and a couple others with new fuses and still nothing
Old Apr 19, 2012 | 01:24 PM
02modlanceroz's Avatar
check and make sure your dimmer switch is plugged in the entire way. if the switch is plugged in the entire way, my guess is the dimmer switch went bad.
Old Apr 19, 2012 | 04:17 PM
Montreal's Avatar
the dimmer switch on the steering wheel or the one one the left hand side under the A/C vent?
Old Apr 19, 2012 | 05:02 PM
by the ac vent, the knob that you would turn up and down to adjust the brightness of your odometer cluster. if that switch isn't working, then none of your lights on the dash will come on with the headlights. you can take a flat screw driver to the side of the switch housing and pop the entire housing out. make sure all the wires are connected properly in the harness and that the harness is snapped firmly in place. from what you described its either a loose connection there, or the switch just went bad. good luck, let us know when you resolve the problem
Old Apr 19, 2012 | 05:42 PM
Montreal's Avatar
ok, I unplugged it and pulled it back up and still no luck. Do you think its the dimmer itself? and where can I find it? I didnt see it on autozone.com
Old Apr 19, 2012 | 06:14 PM
thats what i think is the problem
http://www.ebay.com/itm/02-03-04-05-...item27c609b9b1
Old Apr 19, 2012 | 06:40 PM
Montreal's Avatar
thanks bro, your a life saver i'll try this and let you know what happens
Old Apr 19, 2012 | 07:27 PM
Montreal's Avatar
Originally Posted by Joey Trejo
check ground
I tried already
Old Apr 19, 2012 | 07:37 PM
1hotevo9's Avatar
i had the same problem with my right hand turning signal in the gauge cluster, and I had to replace the little bulbs inside
Old Apr 19, 2012 | 07:51 PM
Montreal's Avatar
lol man I really hope thats not the problem
Old Apr 19, 2012 | 08:18 PM
CrAnSwIcK's Avatar
dimmer rheostat p/n MR190954 if you want a brand new one...
