Lancer How To Requests / Questions / Tips If you have any questions, post them in here.
Changing Speakers on 03 CG
Old Sep 21, 2012 | 02:52 PM
Andrew554's Avatar
Hi just wondering how you change both the front two door speakers and the back 2, on the 2003 CG ES model. Thanks
Old Sep 27, 2012 | 02:12 PM
hotrod11686's Avatar
Thumbs up
Welcome to the forums!
You need the stock speaker sizes
  • 5-1/4" is the speaker size for the front and rear
Note: In my lancer I have 6x9 in the rear, with a little bit of tweeking you can install them there since there is enough room for them.
Refer to the following post for a full detailed installation guide
https://www.evolutionm.net/forums/la...kers-subs.html
Also: You don't really need to buy wiring harness adpaters, you can always cut the existing plug and crimp / solder the wires from the new speakers to the car's speaker wires.
Final note: This forum is LOADED with information just ask the search box and it will give you all that information.
ralliartyz250
Nov 6, 2010 10:26 PM
Jcusco407
Mar 31, 2010 05:01 PM
CG5TougeMaster
Jan 26, 2006 11:58 AM
Aussie CG
Lancer Aftermarket Forced Induction Tech
Aug 6, 2005 09:06 AM
willkuo
Mar 11, 2004 09:09 AM
